power problem......
Discussion in 'Controller Boards' started by JOSIO13, Mar 28, 2020.
  1. JOSIO13
    JOSIO13 New
    I have a problem with OpenBuildsCONTROL software.......When i connect my board with this software it no power on.....i try with another software and power was on and motors working.....in fact, it worked for a while but now has stop to working..tnx for help
  2. Gary Caruso
    Hi Josio,
    1) Are you using a BlackBox?
    2) post your GRBL settings here so we can see
    3) what other software works?
    thanks
    Gary
  3. JOSIO13
    JOSIO13 New
    I dont use a BlackBox...Works with Estlcam V11
  4. Gary Caruso
    Hi Josio, If it works with Estlcam then you must have flashed with the estlcam firmware, did you restore back to GRBL?
    Is this an arduino?
    Gary
  5. JOSIO13
    JOSIO13 New
    Estlcam suppotr gbl to....I have restore back to grbl1.1...in the beginning is work ......no is not arduino...i have try with arduino uno to..same problem....i hem do this with makerbase mks dlc v.2....so in the beginning ihas working.......
    It seems to connect fine, so Grbl is running.
    Hard to understand, but
    Do you mean: The motors are not Enabled?
    Is your $4 setting correct for whatever drivers you have (if its enabled, try disabled, and vice versa)
    Refer gnea/grbl for info
    PS: to paste/share your grbl settings, rather than several screenshots - why not just copy the text from the Serial Console tab (;
    Gary Caruso likes this.
  7. JOSIO13
    JOSIO13 New
    Sorry for that...
  8. JOSIO13
    JOSIO13 New
  9. Peter Van Der Walt
    $4=1 ;Invert step enable pin, boolean
    thats for OpenBuilds Blackbox / SparkConcepts xPro, etc... You probably want 0/Disabled
