port closes / disconnects
Discussion in 'General Talk' started by Campbellcastle, Aug 29, 2019.
  1. Campbellcastle
    I have a lead cnc and havent had an problems in the beginning. but now I have a problem that has stopped me in my tracks. ever time i run a gcode it stops in the middle due to disconnect / port closed. I cant get an error message because its a disconnect. If I manually jog around it never happens, only when running code. But ran the same code dozens of times and it hasnt screwed up before any ideas as to how / why I could be getting this issue?
  2. sharmstr
    Power saving settings on your usb port more than likely. This is common and has been discussed around here quite a bit. Here's a thread that explains it a bit more and also provides some other reasons like EMI and how to fix it.
    Port Disconnect
    Gary Caruso likes this.
  3. Campbellcastle
    that did it, thank you for your help
  5. sharmstr
    Hey! Was that always there? I've never noticed that.
