PNP Switch SN04-N2
Discussion in 'CNC Mills/Routers' started by Stephen Charles Lynn, Sep 9, 2023.
  1. Stephen Charles Lynn
    I am about to connect these switches to my Blackbox X32 controller.
    Section 3.4.3 highlights a jumper that needs moving
    I do not appear to have that on my unit?
    Also can someone confirm the connection to the unit
    The data sheet have indicates
    Brown Ve
    Blue Gnd
    Black Sig
  3. kaoscreations
    Hi, I'm returning to this topic because I too will be installing these end stops soon. The only thing is that I see on your instructions to insert blue to the signal, brown to + and black to GND. However, seeing what they indicate on the sensor I see that the BN is 10v, the BK is the npnnc and the BU is 0v. Is it therefore correct to put, in your opinion, BN at +, BK at signal and BU at GND?
    A thousand thanks!!
    Re-check the docs more carefully
    Inductive Blue = GND = Black in our standard extensions
    Inductive brown = v+ = Red in our standard extensions
    Inductive Black = SIG = Blue in our standard extension colors.
    Red as positive and black as GND pretty standard
  5. kaoscreations
    sorry, my mistake!! I didn't see the wires running in the connectors. In fact, it seemed strange to me that the black GND and Red + standard was not respected :) thanks!!!
