PLEASE HELP, can not connect to x32
Discussion in 'Control Software' started by Elliott simmons, Apr 7, 2024.
  1. Elliott simmons
    Somebody please help me, I’ve spent £3000 building a laser table and can’t even get it to connect to a computer,
    I’m using a Mac. It’s an acro 1580 build.
    have tried unplugging everything except usb
    Have tried installing drivers etc
    every time I try to connect to the usb it just says it fails and that is no firmware, I’ve wasted weeks scrolling forums trying everything, somebody please please help me
    Any known miswirings, incorrect PSUs, incorrect type of Plasma etc? (If known best to declare - otherwise we chase the other causes - but the controller has been damaged)
    Other than that, trying a different PC is worth a shot.
    Checkout the comprehensive FAQ on docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation]
  3. Elliott simmons
    No known misswiring, I was able to control the unit through the touch interface, toggle the lazer on and off etc,
    however I have been unable to connect to a printer to properly set up the machine, I have tried absolutely everything in that usb faq you mentioned, I have tried it on 2 macs now, my older one and I went out and got a newer one just for this but still no luck, trying to aquire a third computer but on a windows operating system to triple check
    failing that I have no idea what to do
    thank you for the message if there is anything else you can suggest would be greatly appreciated
    Did you follow the specific steps for the Mac in the driver's Release notes (In the same zip you downloaded where the DMG is)?
    Try a Windows PC to see if its a Mac issue or a hardware issue.
  5. Elliott simmons
    I have unblocked the relative extensions on every driver variation that I have tried, I didn’t want to consider the unit was faulty as it is brand new but I’m not too sure what it could be
    Try a Windows PC to rule out Hardware?
    Every unit is extensively tested (including USB comms as part of firmware flashing and the test procedure) in the factory. So if its a faulty device now - the next question would be what damaged it (Section 6.3.1 of docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation] coming into play)
  8. Elliott simmons
    [17:36:53] [ ] entry 0x400805e4
    [17:36:53] [ ] Brownout detector was triggered
    [17:36:53] [ ] ets Jun 8 2016 00:22:57
    [17:36:53] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:36:53] [ ] configsip: 0, SPIWP:0xee
    [17:36:53] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:36:53] [ ] mode:DIO, clock div:2
    [17:36:53] [ ] load:0x3fff0030,len:1184
    [17:36:53] [ ] load:0x40078000,len:12784
    [17:36:53] [ ] load:0x40080400,len:3040
    [17:36:54] [ ] Brownout detector was triggered
    [17:36:54] [ ] ets Jun 8 2016 00:22:57
    [17:36:54] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:36:54] [ ] configsip: 0, SPIWP:0xee
    [17:36:54] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:36:54] [ ] mode:DIO, clock div:2
    [17:36:54] [ ] load:0x3fff0030,len:1184
    [17:36:54] [ ] load:0x40078000,len:12784
    [17:36:54] [ ] load:0x40080400,len:3040
    [17:36:54] [ ] entry 0x400805e4
    [17:36:55] [ ] Brownout detector was triggered
    [17:36:55] [ ] ets Jun 8 2016 00:22:57
    [17:36:55] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:36:55] [ ] configsip: 0, SPIWP:0xee
    [17:36:55] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.SLAB_USBtoUART
    [17:36:55] [ disconnect ] PORT INFO: Port closed
    [17:37:11] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Firmware
    [17:37:11] [ connect ] Checking for firmware on /dev/tty.usbserial-0001
    [17:37:11] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:37:11] [ ] Brownout detector was triggered
    [17:37:11] [ ] ets Jun 8 2016 00:22:57
    [17:37:11] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:37:11] [ ] configsip: 0, SPIWP:0xee
    [17:37:11] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:37:11] [ ] mode:DIO, clock div:2
    [17:37:11] [ ] load:0x3fff0030,len:1184
    [17:37:11] [ ] load:0x40078000,len:12784
    [17:37:11] [ ] load:0x40080400,len:3040
    [17:37:11] [ ] entry 0x400805e4
    [17:37:11] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:37:12] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:37:12] [ ] Brownout detector was triggered
    [17:37:12] [ ] ets Jun 8 2016 00:22:57
    [17:37:12] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:37:12] [ ] configsip: 0, SPIWP:0xee
    [17:37:12] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:37:12] [ ] mode:DIO, clock div:2
    [17:37:12] [ ] load:0x3fff0030,len:1184
    [17:37:12] [ ] load:0x40078000,len:12784
    [17:37:12] [ ] load:0x40080400,len:3040
    [17:37:12] [ ] entry 0x400805e4
    [17:37:13] [ ] Brownout detector was triggered
    [17:37:13] [ ] ets Jun 8 2016 00:22:57
    [17:37:13] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:37:13] [ ] configsip: 0, SPIWP:0xee
    [17:37:13] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:37:13] [ ] mode:DIO, clock div:2
    [17:37:13] [ ] load:0x3fff0030,len:1184
    [17:37:13] [ ] load:0x40078000,len:12784
    [17:37:13] [ ] load:0x40080400,len:3040
    [17:37:13] [ ] entry 0x400805e4
    [17:37:14] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:37:14] [ ] mode:DIO, clock div:2
    [17:37:14] [ ] load:0x3fff0030,len:1184
    [17:37:14] [ ] load:0x40078000,len:12784
    [17:37:14] [ ] load:0x40080400,len:3040
    [17:37:14] [ ] entry 0x400805e4
    [17:37:14] [ ] Brownout detector was triggered
    [17:37:14] [ ] ets Jun 8 2016 00:22:57
    [17:37:14] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:37:14] [ ] configsip: 0, SPIWP:0xee
    [17:37:15] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.usbserial-0001
    [17:37:15] [ disconnect ] PORT INFO: Port closed
    [17:40:20] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Firmware
    [17:40:20] [ connect ] Checking for firmware on /dev/tty.usbserial-0001
    [17:40:20] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:40:20] [ ] Brownout detector was triggered
    [17:40:20] [ ] ets Jun 8 2016 00:22:57
    [17:40:20] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:40:20] [ ] configsip: 0, SPIWP:0xee
    [17:40:20] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:40:20] [ ] mode:DIO, clock div:2
    [17:40:20] [ ] load:0x3fff0030,len:1184
    [17:40:20] [ ] load:0x40078000,len:12784
    [17:40:20] [ ] load:0x40080400,len:3040
    [17:40:20] [ ] entry 0x400805e4
    [17:40:20] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:40:21] [ ] Brownout detector was triggered
    [17:40:21] [ ] ets Jun 8 2016 00:22:57
    [17:40:21] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:40:21] [ ] configsip: 0, SPIWP:0xee
    [17:40:21] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:40:21] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:40:21] [ ] mode:DIO, clock div:2
    [17:40:21] [ ] load:0x3fff0030,len:1184
    [17:40:21] [ ] load:0x40078000,len:12784
    [17:40:21] [ ] load:0x40080400,len:3040
    [17:40:21] [ ] entry 0x400805e4
    [17:40:22] [ ] Brownout detector was triggered
    [17:40:22] [ ] ets Jun 8 2016 00:22:57
    [17:40:22] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:40:22] [ ] configsip: 0, SPIWP:0xee
    [17:40:22] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:40:22] [ ] mode:DIO, clock div:2
    [17:40:22] [ ] load:0x3fff0030,len:1184
    [17:40:22] [ ] load:0x40078000,len:12784
    [17:40:22] [ ] load:0x40080400,len:3040
    [17:40:22] [ ] entry 0x400805e4
    [17:40:23] [ ] Brownout detector was triggered
    [17:40:23] [ ] ets Jun 8 2016 00:22:57
    [17:40:23] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:40:23] [ ] configsip: 0, SPIWP:0xee
    [17:40:23] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:40:23] [ ] mode:DIO, clock div:2
    [17:40:23] [ ] load:0x3fff0030,len:1184
    [17:40:23] [ ] load:0x40078000,len:12784
    [17:40:23] [ ] load:0x40080400,len:3040
    [17:40:23] [ ] entry 0x400805e4
    [17:40:24] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.usbserial-0001
    [17:40:24] [ disconnect ] PORT INFO: Port closed
    [17:40:28] [ connect ] PORT INFO: Port is now open: /dev/tty.SLAB_USBtoUART - Attempting to detect Firmware
    [17:40:28] [ connect ] Checking for firmware on /dev/tty.SLAB_USBtoUART
    [17:40:28] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:40:28] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:40:29] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:40:32] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.SLAB_USBtoUART
    [17:40:32] [ disconnect ] PORT INFO: Port closed
    [17:40:35] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Firmware
    [17:40:35] [ connect ] Checking for firmware on /dev/tty.usbserial-0001
    [17:40:35] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:40:36] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:40:36] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:40:39] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.usbserial-0001
    [17:40:39] [ disconnect ] PORT INFO: Port closed
    [17:41:01] [ usb ports ] Detected a change in available ports: [/dev/tty.BLTH][/dev/tty.Bluetooth-Incoming-Port]
    [17:41:03] [ usb ports ] Detected a change in available ports: [/dev/tty.BLTH][/dev/tty.Bluetooth-Incoming-Port][/dev/tty.usbserial-0001][/dev/tty.SLAB_USBtoUART]
    [17:41:08] [ usb ports ] Detected a change in available ports: [/dev/tty.BLTH][/dev/tty.Bluetooth-Incoming-Port]
    [17:41:15] [ usb ports ] Detected a change in available ports: [/dev/tty.BLTH][/dev/tty.Bluetooth-Incoming-Port][/dev/tty.usbserial-0001][/dev/tty.SLAB_USBtoUART]
    [17:41:18] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Firmware
    [17:41:18] [ connect ] Checking for firmware on /dev/tty.usbserial-0001
    [17:41:18] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:41:18] [ ] Brownout detector was triggered
    [17:41:18] [ ] ets Jun 8 2016 00:22:57
    [17:41:18] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:41:18] [ ] configsip: 0, SPIWP:0xee
    [17:41:18] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:41:18] [ ] mode:DIO, clock div:2
    [17:41:18] [ ] load:0x3fff0030,len:1184
    [17:41:18] [ ] load:0x40078000,len:12784
    [17:41:18] [ ] load:0x40080400,len:3040
    [17:41:18] [ ] entry 0x400805e4
    [17:41:18] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:41:19] [ ] Brownout detector was triggered
    [17:41:19] [ ] ets Jun 8 2016 00:22:57
    [17:41:19] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:41:19] [ ] configsip: 0, SPIWP:0xee
    [17:41:19] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:41:19] [ ] mode:DIO, clock div:2
    [17:41:19] [ ] load:0x3fff0030,len:1184
    [17:41:19] [ ] load:0x40078000,len:12784
    [17:41:19] [ ] load:0x40080400,len:3040
    [17:41:19] [ ] entry 0x400805e4
    [17:41:19] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:41:20] [ ] Brownout detector was triggered
    [17:41:20] [ ] ets Jun 8 2016 00:22:57
    [17:41:20] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:41:20] [ ] configsip: 0, SPIWP:0xee
    [17:41:20] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:41:20] [ ] mode:DIO, clock div:2
    [17:41:20] [ ] load:0x3fff0030,len:1184
    [17:41:20] [ ] load:0x40078000,len:12784
    [17:41:20] [ ] load:0x40080400,len:3040
    [17:41:20] [ ] entry 0x400805e4
    [17:41:21] [ ] Brownout detector was triggered
    [17:41:21] [ ] ets Jun 8 2016 00:22:57
    [17:41:21] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:41:21] [ ] configsip: 0, SPIWP:0xee
    [17:41:21] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:41:21] [ ] mode:DIO, clock div:2
    [17:41:21] [ ] load:0x3fff0030,len:1184
    [17:41:21] [ ] load:0x40078000,len:12784
    [17:41:21] [ ] load:0x40080400,len:3040
    [17:41:21] [ ] entry 0x400805e4
    [17:41:22] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.usbserial-0001
    [17:41:22] [ disconnect ] PORT INFO: Port closed
    [17:41:32] [ connect ] PORT INFO: Port is now open: /dev/tty.SLAB_USBtoUART - Attempting to detect Firmware
    [17:41:32] [ connect ] Checking for firmware on /dev/tty.SLAB_USBtoUART
    [17:41:32] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:41:32] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:41:33] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:41:36] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.SLAB_USBtoUART
    [17:41:36] [ disconnect ] PORT INFO: Port closed
  9. Peter Van Der Walt
    Yip short between V+ and GND
  10. Elliott simmons
    this was the only code I have been receiving, just now I changed the usb cable and got that extra code for the first time which was the piece with the short message
  11. Elliott simmons
    has the short damaged the controller? how would I find what's created the short? I'm so sorry I am a first time laser user and am struggling, I really appreciate the help
  12. Elliott simmons
    [17:52:28] [ connect ] PORT INFO: Port is now open: /dev/tty.SLAB_USBtoUART - Attempting to detect Firmware
    [17:52:28] [ connect ] Checking for firmware on /dev/tty.SLAB_USBtoUART
    [17:52:28] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [17:52:28] [ ] KN��~����n��pn�~�l�p���n�rl���|�������~������n�n��n�n�rlets Jun 8 2016 00:22:57
    [17:52:28] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:52:28] [ ] configsip: 0, SPIWP:0xee
    [17:52:28] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:52:28] [ ] mode:DIO, clock div:2
    [17:52:28] [ ] load:0x3fff0030,len:1184
    [17:52:28] [ ] load:0x40078000,len:12784
    [17:52:28] [ ] load:0x40080400,len:3040
    [17:52:28] [ ] entry 0x400805e4
    [17:52:28] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [17:52:28] [ ] [MSG:Warning: Failed to initialize SD card]
    [17:52:29] [ ] Brownout detector was triggered
    [17:52:29] [ ] ets Jun 8 2016 00:22:57
    [17:52:29] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:52:29] [ ] configsip: 0, SPIWP:0xee
    [17:52:29] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:52:29] [ ] mode:DIO, clock div:2
    [17:52:29] [ ] load:0x3fff0030,len:1184
    [17:52:29] [ ] load:0x40078000,len:12784
    [17:52:29] [ ] load:0x40080400,len:3040
    [17:52:29] [ ] entry 0x400805e4
    [17:52:29] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [17:52:29] [ ] [MSG:Warning: Failed to initialize SD card]
    [17:52:30] [ ] Brownout detector was triggered
    [17:52:30] [ ] ets Jun 8 2016 00:22:57
    [17:52:30] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:52:30] [ ] configsip: 0, SPIWP:0xee
    [17:52:30] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:52:30] [ ] mode:DIO, clock div:2
    [17:52:30] [ ] load:0x3fff0030,len:1184
    [17:52:30] [ ] load:0x40078000,len:12784
    [17:52:30] [ ] load:0x40080400,len:3040
    [17:52:30] [ ] entry 0x400805e4
    [17:52:30] [ ] [MSG:Warning: Failed to initialize SD card]
    [17:52:31] [ ] Brownout detector was triggered
    [17:52:31] [ ] ets Jun 8 2016 00:22:57
    [17:52:31] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:52:31] [ ] configsip: 0, SPIWP:0xee
    [17:52:31] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:52:31] [ ] mode:DIO, clock div:2
    [17:52:31] [ ] load:0x3fff0030,len:1184
    [17:52:31] [ ] load:0x40078000,len:12784
    [17:52:31] [ ] load:0x40080400,len:3040
    [17:52:31] [ ] entry 0x400805e4
    [17:52:31] [ ] [MSG:Warning: Failed to initialize SD card]
    [17:52:32] [ ] Brownout detector was triggered
    [17:52:32] [ ] ets Jun 8 2016 00:22:57
    [17:52:32] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [17:52:32] [ ] configsip: 0, SPIWP:0xee
    [17:52:32] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [17:52:32] [ ] mode:DIO, clock div:2
    [17:52:32] [ ] load:0x3fff0030,len:1184
    [17:52:32] [ ] load:0x40078000,len:12784
    [17:52:32] [ ] load:0x40080400,len:3040
    [17:52:32] [ ] entry 0x400805e4
    [17:52:32] [ ] [MSG:Warning: Failed to initialize SD card]
    [17:52:32] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.SLAB_USBtoUART
    [17:52:32] [ disconnect ] PORT INFO: Port closed
    this is the closest ive gotten so far hahah
  13. Elliott simmons
    [18:02:55] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Firmware
    [18:02:55] [ connect ] Checking for firmware on /dev/tty.usbserial-0001
    [18:02:55] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [18:02:56] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [18:02:56] [ ] ets Jun 8 2016 00:22:57
    [18:02:56] [ ] rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [18:02:56] [ ] configsip: 0, SPIWP:0xee
    [18:02:56] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [18:02:56] [ ] mode:DIO, clock div:2
    [18:02:56] [ ] load:0x3fff0030,len:1184
    [18:02:56] [ ] load:0x40078000,len:12784
    [18:02:56] [ ] load:0x40080400,len:3040
    [18:02:56] [ ] entry 0x400805e4
    [18:02:56] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [18:02:56] [ ] Brownout detector was triggered
    [18:02:56] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [18:02:57] [ ] Brownout detector was triggered
    [18:02:57] [ ] ets Jun 8 2016 00:22:57
    [18:02:57] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [18:02:57] [ ] configsip: 0, SPIWP:0xee
    [18:02:57] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [18:02:57] [ ] mode:DIO, clock div:2
    [18:02:57] [ ] load:0x3fff0030,len:1184
    [18:02:57] [ ] load:0x40078000,len:12784
    [18:02:57] [ ] load:0x40080400,len:3040
    [18:02:57] [ ] entry 0x400805e4
    [18:02:58] [ ] Brownout detector was triggered
    [18:02:58] [ ] ets Jun 8 2016 00:22:57
    [18:02:58] [ ] rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [18:02:58] [ ] configsip: 0, SPIWP:0xee
    [18:02:58] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [18:02:58] [ ] mode:DIO, clock div:2
    [18:02:58] [ ] load:0x3fff0030,len:1184
    [18:02:58] [ ] load:0x40078000,len:12784
    [18:02:58] [ ] load:0x40080400,len:3040
    [18:02:58] [ ] entry 0x400805e4
    [18:02:59] [ ] load:0x3fff0030,len:1184
    [18:02:59] [ ] load:0x40078000,len:12784
    [18:02:59] [ ] load:0x40080400,len:3040
    [18:02:59] [ ] entry 0x400805e4
    [18:02:59] [ ] Brownout detector was triggered
    [18:02:59] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.usbserial-0001
    [18:02:59] [ disconnect ] PORT INFO: Port closed
  14. Peter Van Der Walt
    The log output isn't going to magically change. Stop posting it and go to work checking your wiring against docs.openbuilds.com/blackbox-x32
    Brownouts = microcontroller not receiving sufficient power. So likely either a short on V+ to GND as mentioned above (and cautions about in the documentation on relevant pages with a big IMPORTANT NOTE section) or are you using something 3rd party (not our PSU?) that fried the onboard regulator? Or is the laser module at blame? Read section 6.3.1 of the USB Troubleshooting guide docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation]
    as advised earlier in this thread
