PlasmaCAM CNC plasma cutter machine.
Discussion in 'General Talk' started by Keith Parker, Nov 27, 2023.
  1. Keith Parker
    Hi, everyone can someone tell me if the black box motion control system x32 works on a PlasmaCAM CNC plasma cutter machine?
    Most plasmas are just an XYZ table, and the BlackBox Relay to trigger the Inverter, so likely yes: See
    docs:blackbox-x32:connect-plasma [OpenBuilds Documentation]
    Just make sure your Inverter is LF/Blowback (not HF)
    If you want to re-use existing stepper motors make sure their electrical specs are in line (otherwise replace with our motors).
    We strongly recommend our filtered Xtension Limits and our PSU to make sure it all works nicely.
  3. Keith Parker
    Thank you, Peter.
