Plasma - post cut delay
Discussion in 'Laser Cutters' started by Adam3109, Jun 20, 2024.
  1. Adam3109
    Adam3109 New
    I have found with my plasma that I need ~ 10s delay before commencing the next cut, this is the length of time it takes for the airflow to stop following the M5 command on my plasma torch. If I don't delay then the pilot arc does not fire and the next cut is missed (although sometimes it works - hit and miss) I have been adding G4 P10 manually between each cut in the gcode generated by Fusion 360 and 100% success torch fires for every cut. Is there a field I can add a post cut delay in the post processor so it is automatically applied in the code?
    there is not currently such a setting but I am busy adding some stuff to the post so I can add that to the post settings.
  3. Adam3109
    Adam3109 New
    Hi David - Many thanks for your response, it would be fantastic if you were able to add it to the post settings!
