Any chance the compressor tank had trained during the nicer bit, then kicked in the compressor to run - while it was making the choppier bit? Looks almost like the air pressure was fluctuating, which could be explained if its a piston type compressor and it was running at the time?
What's the machine itself? What kind of drive system? More info you give the better the guesses we can try (;
