Peck Drilling
Discussion in 'CNC Mills/Routers' started by ricklach, Apr 6, 2021.
  1. ricklach
    ricklach Well-Known
    I need to drill a number (40-50) of 1/8 inch holes in various aluminum parts ranging to 3/4 inch. What is the best bit and bit parameters for that job. My machine as shown Openbuilds 1510. My first attempt broke the bit after 2 holes.
  2. Kevon Ritter
    Kevon Ritter Veteran
    It's a heat issue. You NEED some form of active chip evacuation and cooling if you want to drill that deep and that many holes. Heat builds up really quickly when chips are recut. The brake happens after the end mill has welded itself. TiCN and ZRN coatings work well with aluminum. AVOID anything with aluminum in it such as AlTiN. You'll be better off with no coating.
    On my Sphinx (Bosch Palm Router), I stuck to this, but that's not going to last in a 3/4" hole either unless you have the above.
    • 3mm diameter, 1mm peck, 40mm plunge, 20k rpm
    Drilling and routers don't really go well together due to the high rpm. A boring operation would be ideal if the hole was any larger.
  3. Gary Caruso
    Spot drill with the cnc then manual drill the rest of the way.
    Gary
    Kevon Ritter likes this.
  4. ricklach
    ricklach Well-Known
    Thanks, I will try the spot drilling. Should I lower the rpm on the router? Any particular bit recommendations?
    Rick
  5. Gary Caruso
  6. ricklach
    ricklach Well-Known
    Done, Thanks Gary.
    Rick
  7. Kevon Ritter
