OX XAxis to use acme lead screw
Discussion in 'CNC Mills/Routers' started by Stirlingmw, Apr 28, 2019.
  1. Stirlingmw
    Afternoon all
    I have sort of converted my old (ish) Cbeam machine to operate more like a OX machine. In other words I have added a set of OX plates to my original set up. The problem I am getting is when I am cutting the X Axis seems to judder and stall. My Y and Z axis are using acme lead screws, but my X axis is using a GT3 Timing belt.
    I have altered my settings in grbl Planel to reflect the $100 x axis step change and slowed the $110 max rate. A couple of questions.
    1. Would the juddering/stalling be a result of these settings? and what would be the most ideal setting (Using a Nema23).
    2. Is there a way I can convert my X axis to use an acme lead screw utilising the Ox plates?
    Thanks in advance
    Steve
