OX AI
Discussion in 'CNC Mills/Routers' started by Robert Hummel, Feb 3, 2014.
  1. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Milling away :)
    Pic of the rough mill, second operation is the finishing pass and cut out ;)
  2. Robert Hummel
    Moderator
    On to the next plates for the x
    Milled 3 of the first, cleaning and tapping the holes as these mill ;)
    We'll with in my time frame :D
  3. Robert Hummel
    Moderator
    And that's a night of milling ;)
    Back to my 3D printer and Stinger projects till tomorrow :)
  4. Robert Hummel
    Moderator
    Ends supports milling as I post ;)
  5. GrayUK
    Hi Robert.
    I know you really are a busy man, but can you get back to me with a price when you're free?
    Gray
  6. KerryH
    KerryH New
    What's happened with the files?
  7. Robert Hummel
    Moderator
    I will be posting the files in sketchup format with the cam operations in place so the sketchucam plug-in will be required.
    I just need to find time to sit down at the PC and upload things lol so little time
    I do almost everything on my phone :p
    KerryH likes this.
  8. Robert Hummel
    Moderator
    All the left supports done!
    On to the right :)
  9. Jimmy Alenius
    Hi Robert! Is it possible to buy aluminium parts for the OX from you? If so, what would it cost?
    Edit: PM me at [email protected]
    Best Regards / Jimmy Alenius
    #219 Jimmy Alenius, Jul 6, 2014
  10. Robert Hummel
    Moderator
    All end supports milled
    Z axis plates are next :)
  11. Robert Hummel
    Moderator
    Main plates milling now.
    Little behind due to some work for a friend that will always come first :)
    Fresh off the mill and holes tapped :)
  12. Robert Hummel
    Moderator
    Z Axis plates are done and fit NEMA23 motors / have tapped holes for nut less install
    All that's left are the left main plates and belt clips along with clean up to remove scuff marks
    If I have enough 65mm M5 on hand I will also include 4 in each kit.
    If I get more acrylic in time I will also include spacers for all motors.
  13. Jimmy Alenius
    Have you a price incl. shipping to Sweden?
  14. Robert Hummel
    Moderator
    I'm going to the post tomorrow, I will get the quote in person so it's right.
    Estaminet software on the site sucks and always says more :/
  15. Jimmy Alenius
    Great! Need to know before I put an order :)
  16. Joel Brown
    I am interested in a set of OX plates shipped to FLA. Price and availability is greatly appreciated.
  17. Terje Moe
    Terje Moe New
    Hello Robert
    Do you still have a scratch and dig set? If not how long is your list for a regular set? Can you please mail at [email protected].
    Terje
  18. joe.carson
    Hi Robert, I would like to buy from you an OX kit. I wrote you a PM through the openbuilds.com platform.
    Thanks and regards, Joe
  19. Robert Hummel
    Moderator
    The kits are back on track and will be done soon, the Z plate will accept Nema 17 and 23
    I am milling the last plates now and then it's just clean-up
  20. Robert Hummel
    Moderator
    Since the demand is going crazy again I will be milling more after these, but it takes time that is limited for me so please bare with me and I will try to get as many of you going on your OX as possible.
    The three kits are now spoken for I'm sure, so a wait time on the next sets will be no less then two weeks.
  21. GrayUK
    Hi Robert.
    They look sooooo good! Don't they? :thumbsup: :thumbsup: :thumbsup:
    Gray
  22. Robert Hummel
    Moderator
    Indeed !
    Milling the last left main plate now
    Then the clips and motor spacers :)
    The rest is clean up and packing ;)
  23. joe.carson
    Hi Robert,
    I provided as PM my full shipping address to determine the shipping costs.
    Thanks for your help.
    Best Regards
    Joe
  24. Robert Hummel
    Moderator
    Got it :)
    I will be picking up the 1/8 plate to mill the belt clips today.
    Once I have the kits done and packed I will be know shipping cost, I don't know the end weight of the packages yet
  25. joe.carson
    Hi Robert,
    Thanks for your feedback. I look forward to hearing from you.
    Best Regards / Joe
  26. Robert Hummel
    Moderator
    Clips done!
    On to the spacers and then a bunch of cleaning
  27. Dave Millard
    Hi Robert
    Please will you share your process for cleaning the aluminium. I am sure you have perfected an efficient methodology for getting it done quickly.
    Thanks very much.
  28. Robert Hummel
    Moderator
    A sanding block, wire brush, 600,800 grit wet paper and dish soap.
    Wire brush in the drill using no pressure in one direction.
    Then wet sand in one direction 600 then 800 using dish soap and water ,rinse and dry :)
    I am in the middle of building a bead blasting box and saving for a good compressor to get even flow.
    Then the finish will be just awesome.
    I may even do a one of set in gold paint finish after it's done ;)
    Dave Millard likes this.
  29. GrayUK
    I am surprised you haven't anodised them
  30. Robert Hummel
    Moderator
    :) lol that is also in the works, got my hands on some awesome power resistors that will work perfect
