OX AI
Discussion in 'CNC Mills/Routers' started by Robert Hummel, Feb 3, 2014.
  1. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Well all the v-slot is cut ;)
    This should give me lots of tie down options :D
  2. sgspenceley
    sgspenceley Veteran
    Love the hold down solution.
    Robert Hummel likes this.
  3. KerryH
    KerryH New
    Robert your work is an inspiration, Thanks for sharing with the community!
  4. Robert Hummel
    Moderator
    It is the gratitude like this that makes it worth while and so easily shared on my part :)
    Also making great friends and interacting with like minded individuals has contributed to my projects succeeding ;)
    Special thanks must go out to @dddman as your help has touched my little angles heart and she cant wait to start printing on the i3 :thumbsup:
    GrayUK, sgspenceley and KerryH like this.
  5. dddman
    dddman Journeyman
    I hope she likes her frog! I'm pretty sure she will print the whole family! I'll have to make the 7 hour ride someday to meet you @Robert Hummel . 700km and the language barrier didn't stop us! We will have a frog army! Or maybe an i3 army!
  6. Robert Hummel
    Moderator
    Well I got the E3Dv6 installed on the i3 and finished packing up the OX AI kit :)
    The kit is up for grabs as I have caught up on all of my outstanding orders, first come, first serve ;)
    Here's a pic of the hotend
    juanmahl and Krishnakumar like this.
  7. juanmahl
    juanmahl New
    Robert,
    i3 printer looks nice.
    Which model is that extruder? Could you provide a link?
    is it a lead screw on the z axis?
  8. dddman
    dddman Journeyman
  9. juanmahl
    juanmahl New
    dddman,
    E3D V6 is the hotend, not the extruder.
    I ask for the green plastic parts in the picture, the part that pushes the filament into the hotend, do you know where to get the stl files?
    Also if there're lead screws in the z axis, do you know the part name or the link for the part that holds the leadscrew nut and is kept in place using the vertical linear shaft?
    I'm improving my i3 and I really liked the idea of using lead screw for the z axis, I think it could stop z-ribbing in my prints.
  10. dddman
    dddman Journeyman
    I've printed them :p I'll give you the links it won't be too long. I misread for the extruder :)
    Daryl likes this.
  11. dddman
    dddman Journeyman
    juanmahl and Robert Hummel like this.
  12. Robert Hummel
    Moderator
    Well looks like the i3 is up and running first :)
    Ty dddman!
    Now to get this OX done!
  13. Rlwilson2
    Rlwilson2 New
    Looking to build a 4' x 4' OX with your plates. Full Nema 23.. Let me know a price for a full kit of plates and expected time frame. Shipping will be to 38555. I can do finish sanding and clean up on plates if needed.. [email protected]
  14. Mopar32985
    Mopar32985 Well-Known
    See if any of you guys might be able to give me some input. I have an OX running a hobby CNC board and im having difficulties running slower feed rates but none at all during higher here are my motor tuning in Mach3. All steppers are having same problem and same setup. Also I did check my grounds like Robert suggested all look good. Only motor thats not doing this is my Nema17 on the z axis. Any help would be greatly appreciated.
    Velocity 1000
    Acceleration 200
    G's 0.020395. . . . .
    step Pulse 5
    Dir Pulse 5
    Also i am running 1/8 micro stepping on an older computer i see this the worst when changing directions or making a slow diagonal cut. Could this be to much processing for my computer
    #464 Mopar32985, Feb 14, 2015
  15. ngoodfellow
    what is the thickness of these plates?
  16. Robert Hummel
    Moderator
    1/4" 6061
  17. Justin Christensen
    Very nice job on your Ox. I am wanting to build my own Ox. I am pretty new to the CNC world but am wanting to learn. I think an Ox would be a great first build. Wondering how much for your parts shipped to Utah. Please email me when you can [email protected] thanks for your time.
  18. Justin Christensen
    On the Nema 17 motor for the Z axis, what is the purpose for putting so many spacers on it? Is it better to be up higher?
  19. Kyo
    Kyo Veteran
    Most of the time when you see spacers or risers on a motor mount for a lead screw driven axis Like the Z axis. They are there to allow clearance for the motor / rod Coupler. Like this sketchup example. If the Motor was to be mounted directly to the plate without spacers you effectively lose travel distance by the space that would be taken up with the coupler.
  20. Justin Christensen
    I'm looking to order some V-slot. I was trying to figure out what sizes I need to order. Do you have any good pictures of the base?
    I'm going to make mine 40"x 30" (1000mm x 750mm) and just need to figure out how much of each sizes I'll need. If you could post a few pics of the base that would be awesome. Thank you
  21. Donald D. Parker
    Hi Robert, I have been trying to get templates for the plates which I can print on my inkjet print, then hand cut the plate from aluminum scaps that I buy from Lifetimer Boats for $2.50cdn / pound. Everything I download from OB will not print at actual size and will not give me dimension so I could hand draw my own. What would you charge for some actual size templates. Also how much are your plates delivered to Cowichan Bay, BC, V0R 1N1?
    Don Parker
  22. KerryH
    KerryH New
    Try this:
    http://help.sketchup.com/en/article/114462
    I select "parallel projection" and then "top" from the "standard views" menu
    Also see the dimensioning tool from the "large tool set" available on the "view" > "tool palettes" menu. http://help.sketchup.com/en/article/94982
    I've used it successfully to make some parts by hand see http://imgur.com/a/CbSmt
  23. Donald D. Parker
    Thank you, Kerry I will try that.
  24. Donald D. Parker
    Thx Kerry, I tried it and it works but not very good, unless I missed something. I got another suggestion from Kyo that I will try.
  25. Rick 2.0
  26. KerryH
    KerryH New
    Ya sketchup can be a little finicky about the process.
    Another tip that helps is to size down your sketchup window from being maximized to just large enough to display the model.
    What i mean by this is instead of having your window like this:
    You want to minimize the amount of white space around your model like this:
    Also you want to change the settings in the print dialog box from:
    mainly unchecking the "fit to page" option and fixing the the scale, to this:
  27. Dave Landry
    Hi Don,
    did you ever get a quote?
  28. Donald D. Parker
    No, I didn't, I just made some generic aluminum plates for the intial build and will route my own with my OX. I am almost ready to assemble but got distracted by my Segway build.
    Dave Landry likes this.
  29. Traxxtar
    Traxxtar New
    Are kits still available for purchase?
  30. crazerico
    crazerico New
    where the gcodes ever published?
    i know this is an old thread
    dean3 likes this.
