optical endstops
Discussion in 'General Talk' started by Dale Y, Dec 14, 2018.
  1. Dale Y
    Dale Y New
    Looking to add optical endstop(s) to my CNC router. The problem I am having is finding the right one. In particular, I want to get one to detect the end of whatever bit I have installed to set my Z axis, but so far I have not found any that would be wide enough. Anybody here got some suggestions?
  2. Kevon Ritter
    Kevon Ritter Veteran
    An optical limit may not be the best idea consiy that there will be chips/dust flying around.
    If you are absolutely dead set on this, check DigiKey. I know they have wider optical switches. You also didn't mention what "wide" is.
  3. Dale Y
    Dale Y New
    What I am thinking is something that the opening is wide enough to allow me to home the router bit. So far, the only ting I have found only as approx 3/16 opening. I was hoping for something to allow a wider bit.
  4. Rob Taylor
    Optical toolsetters are usually laser-based, not IR LED like limits. I'm assuming this is so they can be focused to a very narrow beam with a very crisp edge in order to get the best possible- and repeatable- "snap" action as the tool enters the beam.
