Openbuilds xyz probe not working
Discussion in 'OpenBuilds Forum Help' started by Soultie, May 3, 2023.
Tags:
  1. Soultie
    Soultie New
    The Lead 1515 does not do anything when I use the "Automatic" probe wizard, or the "xyz" probe wizard. Individual axis probing works fine. Touching the magnet to the probe lights up the LED's on the probe and the blackbox x32, as does touching the probe to the bit with the magnet attached to it. The troubleshooting section of the CONTROL software indicates that the probe is responsive. But every time I click automatic or xyz, the machine is unresponsive - it just doesnt start the probing process or move at all. After a minute of waiting, I eventually hit abort, disconnect, then reconnect. The weird thing is, as soon as I reconnect, the machine quickly moves to the center of the probe like its about to check bit length. Not sure what could be wrong, any help is appreciated.
    Did you follow all the setup steps in the BlackBox documentation (Particularly, make sure you didn't skip section 7.1?)
    If you did, please do follow section 7.1 (and have a read through section 7.2)
  3. Soultie
    Soultie New
    :) I did not update the firmware, I will do that ASAP. Thanks for your time!
