OpenBuilds X32 BlackBox firmware upgrade
Discussion in 'Controller Boards' started by GS76, Dec 24, 2023.
Tags:
  1. GS76
    GS76 Well-Known
    To whom it may concern:
    I am running v1.0370 Openbuilds Control software with the OpenBuilds X32 BlackBox controller.
    Should I be checking for the latest GRBLHAL firmware on the hardware (controller)?
    Thank you for the assistance.
    Thank you for the excellent hardware and software.
    yes, install the latest firmware from the Wizards and tools|firmware flashing menu in OpenBuildsCONTROL
    Yes the version included is what we consider to be current / supported / no known issues / all compatible with CONTROL
    If you want cutting edge you can grab later builds from grblHALs Web Builder too
  4. GS76
    GS76 Well-Known
    Hi Peter,
    Thank you for the information.
    How do I access the grblHALS Web Builder builds and how would I flash it to the X32?
    Thank you.
  6. GS76
    GS76 Well-Known
  7. David the swarfer
    no performance changes that I know of at this time. if it is working please leave it alone (-:
    Nothing you really need. Do you like stable and tested or cutting edge
  9. GS76
    GS76 Well-Known
    Thank you as always, Peter,
  10. Flyer@2
    Flyer@2 New
    Not sure if this is the right place for this but I downloaded open builds control version. 1.0.370 and flashed the Arduino Uno R3 and it worked perfectly then later it updated to the current version 1.0.371 and I was doing some re flashing and I got continued failures. I fortunately had the previous version and I reinstalled and did get the Arduino to flash. in the newer version the black box X4 is missing and that is what the older version still has. I am new to this program and it is a learning curve, but i really need to know what the problem was ? a glitz in the new version or Arduino not supported
  11. David the swarfer
    a temporary 'not supported', it will come back....
  12. Flyer@2
    Flyer@2 New
    with a new version?
  13. Peter Van Der Walt
  14. Flyer@2
    Flyer@2 New
    OK I see, thanks.
