OpenBuilds X32 BlackBox: 0 - 3.3 V PWM to 0 - 5 V PWM
Discussion in 'Controller Boards' started by GS76, Dec 11, 2023.
  1. GS76
    GS76 Well-Known
    To whom it may concern:
    I am using the 0 - 3.3 V PWM output to signal an external speed controller for a brushless motor for my spindle.
    The controller can take up to 5 V which means the potential speed the spindle can achieve is reduced by the ratio of 3.3/5 = 66 % of its maximum speed.
    Has anyone created a voltage divider to step up the 0 - 3.3 V to 0 - 5 V, if possible?
    By the way fantastic controller and software.
    Any suggestions or recommendations would be appreciated.
    Regards,
    Gary
  2. GS76
    GS76 Well-Known
    Just make sure that 3rd party spindle controller doesnt overload the output, nor backfeed - have seen some ESC/Brushless controllers from the far east burn out BlackBoxes. Take measurements before hooking up :)
  4. GS76
    GS76 Well-Known
    Thank you Peter,
    Good point no this controller is from Italy. It is already working successfully with the X32 blackbox but as I said I can not reach full speed as I am only able to go up to 3.3 V and the motor controller can accept up to 5 V. Hence, why I am now thinking that I could use the 0 -10 V spindle anlalog signal and step it down some how.
    Are the suggestions or recommendations in this regard.
    Right track with the divider :thumbsup:
  6. GS76
    GS76 Well-Known
    Thank you.
  7. GS76
    GS76 Well-Known
    Thank you for the help and the great documentation in regards to the X32. The controller and software are more impressive the more I use it.
