OpenBuilds WorkBee 1010
Discussion in 'CNC Mills/Routers' started by Mark Carew, Jun 15, 2018.
  1. Scotty Orr
    Scotty Orr Journeyman
    You might have an unsupported "tool change" command in your G-code. There is a brief discussion here: UGS G-Code Operation
    Grbl does not support the M6 command. If you have a line "T1 M6" in your code, you can safely remove it.
    Edit: BTW, I believe if you just "OK" at the error, the rest of the code will execute (I think grbl handles it that way just in case you really do need to do a tool change - temporarily halting.)
  2. Craig Hollabaugh
    Craig Hollabaugh Well-Known
    gnea/grbl
  3. Keith Kimura
    Thanks, Scotty and Craig. Yeah, it was an "M6" command, I did click through it and it continued to run.
    So, now I have connected all the motors and I have a "working" CNC (hooray!). I am just doing some testing by jogging the machine through all of the axes and have found a new problem; the "Y" motors are running at different rates so the Gantry is getting skewed as it travels. I notice the left "Y" motor actually skips while the right motor continues. Because of this the screws are being pushed out of the front of the machine and the flexible coupling is expanding on one side or the other. I also noticed that while idle I can easily turn one of the motors but the other won't turn, but when I disconnect the power the "stuck" motor then turns easily. Any thoughts or solutions?
    MaryD likes this.
  4. Scotty Orr
    You shouldn't be able to turn a motor when powered up and idle. I think check your wiring connections on the "free" motor (maybe test it alone). When energized, it should not turn by hand.
    It's probably skewing because the working motor is dragging the free motor along.
  5. Craig Hollabaugh
    Or your wheels or delrin blocks are too tight
  6. Keith Kimura
    It's been a few days but I've cleaned up the problems with the motors running out of sync. I checked and adjusted the wheels (thanks, Craig), and check all my wiring (thanks, Scotty). I've been doing some jog testing and we are good! But now I have a new problem; I loaded a test toolpath (using Universal G-Code sender) and the CNC is making a very tiny version of what I've designed (I'm just running the machine without a router for test purposes). What have I set incorrectly (or not set) to make this happen? I've done some searches via the Universal G-Code Sender site but can't seem to find anyone else with this problem/solution.
  7. jeffmorris
    jeffmorris Well-Known
    It looks like the toolpath is set to inches and UGS is set to millimeters. Scale the toolpath up 25.4.
  8. Keith Kimura
    I don't know how to scale the toolpath
  9. jeffmorris
    What program did you use to create toolpaths?
  10. sharmstr
    sharmstr Master
    Keith, Do you have a G20 at the beginning of your gcode?
  11. Keith Kimura
    Fusion 360
  12. Keith Kimura
    Yes
  13. Mark Carew
    Staff Member Moderator Project Maker Builder Resident Builder
    Are you perhaps designing in mm and outputting in inches with the post processor from fusion? You should use generic or grbl post processor from fusion in the units you designed in.
    Another factor may be that your steps/per mm jumpers (on the board) are not matching your steps per mm in your grbl settings.
    The jumpers are usually set to 1/8th micro steps ( jumper #1 on and Jumper #2 on, Jumper #3 has no jumper) on the xPRO controller. In the grbl settings the steps per mm on the axis of this lead drive machine should be
    $100=199.100 (x, step/mm)
    $101=199.100 (y, step/mm)
    $102=199.100 (z, step/mm)
  14. Keith Kimura
    That fixed it! Thank you, Mark.
  15. Keith Kimura
    Mark, where can I learn more about GRBL and why this worked?
  16. Keith Kimura
    I have installed Limit Switches to all Axes and wired to xPro Controller. I saw on a previous post the GRBL line command to program the switches with a .5" back-off but now I can't seem to find that post. Can you help me with what the GRBL instruction is?
  17. Mark Carew
    That's great to hear @Keith Kimura :thumbsup:
    *You can read more about grbl
    gnea/grbl
    and here
    Ask Grbl CNC questions here.
    This is where @Sonny Jeon grbls active developer hangs out helping others.
    and be sure to read the xPRO wiki as well ( I am sure you have been here though since you have the home switches wired)
    Spark-Concepts/xPRO
    *On changing the limit back offs to .5"
    Try changing this line in the grbl settings
    $27=3.000 (homing pull-off, mm)
    to
    $27=12.7 (homing pull-off, mm)
    Hope this helps
  18. Mark Carew
    gnea/grbl
    and here
    Spark-Concepts/xPRO
    to
    Hope this helps
  19. stargeezer
    stargeezer Journeyman
    Hi Gang,
    As much as I hate yelling for help, this is one of those times. I've completed the entire build and have enjoyed the entire process, but I'm now in a whole and can't get any further without a bit of help. I have no movement of any stepper motor. I have installed UGS, all wires have been traced over and over. Voltages have been checked and I'm about to hang up the xpro and install a BOB and Mach 3.
    Thanks, Larry
  20. Giarc
    Giarc Master
    I am no expert, but I always see people with issues, or warnings issued about UGS. I have never tried it, but I have tried GRBL panel. It worked the first time and every time. It is a quick and simple download and install. Maybe give it a try. Although, your issue may have nothing to do with UGS, but you never know. I recently posted this to help someone else out. very, very, very new to the CNC world.
  21. Giarc
    Giarc Master
    The other thought I had was maybe UGS did not take the settings you chose for your steppers.
  22. Keith Kimura
    With the Limit Switches wired up and GRBL code $22=1. I send command $H for Homing and Z Axis moves up to contact the Limit Switch and it results in Error 8. According to instructions I've been reading it is supposed to touch each Limit Switch, execute the "Back Off" and re-touch the Limit Switch throughout all Axes, but that's not what's happening. After each event like this the machine needs to be powered off, manually clear the Limit Switch and then $X resets UGS. Where am I going wrong?
  23. Mark Carew
    Hello @stargeezer I agree with @Giarc on this one as I have tried to use UGS but seem to always have a hard time with it working on some pcs but not others. I ended up using grbl panel and it just works. Its not as pretty, mind you, but its stable. Give it a try and lets see if that may be the problem or if its something different.
    @Keith Kimura If at all possible could you also please try grbl panel.
    I am working on a quick video to show a machine we are wiring up now that shows a little more about the home limits added. Will post as soon as its ready
  24. stargeezer
    Hi Mark,
    I want to thank you in advance for the extra work you are giving this project and all the assistance given to us non-programmers.it's a little tough here in the woods sometimes. So far I have tried GRBL panel without success and UGS does nothing at all.Tonight I plan to trace everything from the power source to the steppers looking for any sign of life.
    I actually believe that the problem is in the firmware. If I can get a clean working copy of the firmware and can eliminate that option I believe that I'll be far ahead of where I am now. (i hope).
  25. Mark Carew
    Hi Larry your more than welcome my friend, I am glad to help and I thank you for the kind words.
    We all learn here as a team and thats one of the things I really love about this place and its people.
    I put together a really quick video showing a quick walk through of grbl panel as well as the homing sequence so that you could see what you should be seeing on the screens when its working properly.
    Will be posting this video today. From there we will work on trying to figure out what could be causing your board to not respond so you can get up and running. :thumbsup:
  26. stargeezer
    There are far more than one reason I enjoy shopping at Openbuilds Parts Store!
    Thanks for the help.
  27. Mark Carew
    A quick video to wet the appetite as we work to release wiring and software 'how to videos' on the subject.
  28. Keith Kimura
    Very nice. Much appreciated. Thank you Mark.
  29. Keith Kimura
    So here's my latest problem: the CNC is not cutting according to my designs. The attached photos and pictures show what the planned part is supposed to look like and what the resulting cut parts are coming out as. Straight lines are not straight, radiused corners (.0625 radius) are way to big and lopsided where they should be symmetrical, the hole is cut oval. Is it my speeds and feeds or is it an erroneous toolpath? My toolpath is generated from Fusion360 using GRBL/grbl configuration driver. Using the DeWalt DWP 611 at 27000 rpm, my feedrate is 62.5 in/min with a .125 Dia router bit. ArmHinge_CNC cut wrong.jpg ArmHinge_Plan.jpg ArmSlot_CNC cut wrong.jpg ArmSlot_Plan.jpg BodyHinge_Plan.jpg BodyHinge-CNC cut wrong.jpg
  30. Giarc
    Giarc Master
    Are all your steps/mm the same? They should be close since they are all the same type of screw. If it is not calibrated to be dead on, you may cut ovals (or elongated circles when the should be round). You will get other cutting errors as well.
