OpenBuilds OX CNC Machine
  1. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi @PoppyRoseGifts,
    For my money, the Vectric range of software takes a lot to better. Have a browse of their site and perhaps download a demo version to try before you buy. http://www.vectric.com/
    Tweakie.
  2. PoppyRoseGifts
    Off too look, thanks @Tweakie
  3. oni305
    oni305 Well-Known
  4. Mizuno
    Mizuno New
    I was planning on buying a pre-built machine but then I came upon the OX - looks great and I really want to build one now! I'm interested in making guitars and the router I currently use is 6lbs, could the OX handle that weight? I'd probably be building one with a millable width of of 16". Thanks!
  5. GrayUK
    Hi Mizuno.
    Can you let us know the make and model of the router?
    Likewise, you could browse the many many videos, and see if your router is being used elsewhere.
    Gray
  6. Mizuno
    Mizuno New
    It's a Hitachi M12VC. I've been keeping an eye out and I haven't seen anyone using one with the OX, they've all been smaller ones with weights of about 3-4lbs.
  7. GrayUK
    I think Tweakie or Mark, (Kram242) will be able to answer this better than I can.
    However, I have seen larger Routers, some of the Bosch range, being used.
    Gray
  8. Rich C
    Rich C New
    Since I had to purchase the gshield V4 and seeduino V3 boards from different locations, I am quite sure that the pre-configured grbl software, or any other required software will not be included. What will I need on the software side for these?
    (Where can I get the pre-configured grbl software, etc)
    I am leaning towards BobCAD CAM for designing and milling.
    Rich
  9. SlowBipe
    SlowBipe New
    Does anyone know when Mark is expected to get the 8mm Acme Screw in stock in 300mm length? This item will stop me from finishing my build.
  10. dddman
    dddman Journeyman
  11. Chris Laidlaw
    Chris Laidlaw Well-Known
    Hi Mizuno,
    Paul is using a Bosch 1617EVS on his OX, and it is listed as 7.7 lbs (pby 6 lbs after you strip it down)
    You can see it with my mount in this picture... There is at least one other person hooking up a 1617 to his OX... sent his mount out yesterday.
    #1121 Chris Laidlaw, Aug 12, 2014
    Mizuno likes this.
  12. Rich C
    Rich C New
    Tweakie, or Rick 2.0, or anyone at OpenBuilds....I sent a message back on 9 AUG concerning the v-slot wheel bolts being too short to mount to alum gantry plates....I have yet to even receive a response, so I just went ahead and ordered 30mm screws.....PLUS..I have 3 orders "Awaiting Fulfillment" (one of which was ordered last night, so I can understand that one AF right now).....what is going on with the other two? You guys were AWESOME in the beginning...now I can't seem to get status???? I'm hoping this all is just some accidental oversight...
  13. dddman
    dddman Journeyman
    You can go at 2 minutes 8 seconds in the first video in the builds section. They says to use 30mm screws to compensate for the width of the plate.
  14. Rich C
    Rich C New
    Right....However, I did not realize that the required 30mm screw lengths would not come with the wheels....and when I asked about that, I got zero response....If OpenBuilds pushes using these plates (from whomever makes them) AND identifies 30mm screws in the build video, why would they send the wheels with 25mm screws? and then not even at least identify the 30mm requirement in the parts list? Maybe this should be addressed?
  15. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    I agree that it should be in the BOM if it is not.
    The reason they ship the wheels with 25mm is due to the fact all the plates they sell are only 6.35mm thick.
    So 30mm would be overkill and cause other issues like clearance.
    I use the 25 mm from the wheel kits for the end plates :)
  16. dddman
    dddman Journeyman
    26th item in the part list... ;)
  17. KBill
    KBill New
    Did you print the router mount? Do you have your files posted somewhere? I'm about to embark on an 4x3 OX derivative and would like to see how you made the mount.
    On my current router, I'm using 1/2-8, 2 start lead screw with a Bosch 1617 on it and haven't experienced slipping. NEMA 23 motors.
    Kevin
  18. Rich C
    Rich C New
    dddman...I STAND CORRECTED There are 10pcs of M5x30mm screws on the parts list. doh! My apologies to all.
  19. Mizuno
    Mizuno New
    Excellent, thanks! Now I have to order some aluminum and get to milling.
  20. asb_79
    asb_79 Well-Known
    Hi Kevin,
    I designed the router clamp for Gwandads and my OX build, I have posted the STL's on Thingiverse. I modeled the parts in ProE, it would be fairly simple for me to alter the design to suit other router/spindle diameters.
    http://www.thingiverse.com/thing:398695
    Anthony
  21. Travis
    Travis New
    does anyone have any information on how much of a difference there is between the delrin solid v wheels, compared to the new ploycarbonate solid v wheels. As in how much deflection it prevent compared to the delrin wheels. Or if there is some sort of number figure, as in twice as strong, or so on. Anyway, thx for your time :)
  22. Anthony Babbe
    I am Looking to get started but the only thing is I need to be able to know how much the "Four Plates" cost I have to order in stages and build as I go. This design is Amazing and I am so excited to get started!!! I know there were three names listed at the beginning of this blog but I Live in California, USA. It sounds like this forum and most of the people are not in the States, not a problem as long as i can get the parts.
  23. mybuild14
    mybuild14 New
    Anthony, check with Chris Laidlaw here on Openbuilds. He also sells them on Ebay but you may want to get them direct as I believe he is located in San Jose. Hope this gives you a start and have fun.
    Chris Laidlaw likes this.
  24. Anthony Babbe
    He sent me a PM to let me know about Ebay. Thanks for sharing!!
  25. Mehman Jamalov
    Guest Builder
    Hi, friends. I am new in OX Openbuilds. I would like to know is there any way to elongate v-slot for example 2750 mm. I would like to make a CNC with working area 2710x2450 mm. Or how to join or glue v-slots?
  26. Frederic Goddeeris
  27. Tweakie
    Moderator
  28. GrayUK
    Hi Frederic
    Do you have any better pictures, or videos, showing the pen holder, or any pictures of your build?
    Cheers Gray
  29. Rick 2.0
    Mehman, this subject has been touched on several times in the forums. Unfortunately all the best suggestions are not located in a single thread so you'll have to search around a bit. Here's one to get you started http://www.openbuilds.com/threads/larger-format-machine.313/
  30. Frederic Goddeeris
    At first I used a pencil fixed to the Z beam. It was a pain to find the best position for correct pressure on the pencil
    Now I have glued a marker on a 20x20 beam. The beam is supported by wheels so that the beam and marker do roll down and so that gravity provides the pressure on the marker.
    I installed an bracket on the beam so that the CNC can lift the marker.
    I used hot glue, so I suppose I should be able to replace the marker when needed.
    The build is a standard one as per the 2 instruction video's. The only difference is that I did not have an ACME threaded rod and used standard M8. I addition I plan to install limit switches.
    Frederic
