OpenBuilds MiniMill
Discussion in 'CNC Mills/Routers' started by Mark Carew, May 26, 2017.
  1. Mark Carew
    Hey guys :)
    A quick heads up to let you know that the MiniMill videos have been updated to show the all new Build as well as the new super clean wiring with the all new OpenBuilds limit switches installed! Props go out to @Matthew Bates for the awesome job on the videos.
    Thank you
  2. Mark Carew
    New update: Added Z touch probe to the additional video section :)
  3. Alex Chambers
  4. Lofton Harris
    Hey, Mark, where do I find the updated MiniMill video (wiring and touch probe)?
    Click the Build tab above (ie the MiniMill Build Page), scroll down to the Videos section. Good luck!
  6. Lofton Harris
    Thanks! Found it.
  7. Bruce H
    Bruce H New
    What's the minimum amps required from a 24V power supply to run the mini mill with the hi torque nema 23 motors?
    We recommend 24V Meanwell Power Supply Bundle
    MaryD likes this.
  9. Tbear1123
    Tbear1123 New
    Where did you buy this vise?
  10. Inge
    Inge New
    Is it possible to have this machine with worksize 200x200mm or 250x200mm?
  11. Bruce H
    Bruce H New
    It's only limited by your imagination. You can find other threads here of people who have customized their mini mills. Probably one of the most popular is Scotty Orr's mini mill XL conversion. It gives you a work area much larger than the stock mini mill. MMXL - A MiniMill Conversion
    Scotty Orr and Rick 2.0 like this.
  12. Inge
    Inge New
    Thanks :D
    EDIT:
    just checked the link..it will be too much work...since my skills are rather low :D haha
    ANyway..but it must be possible just to extend X and Y axis a bit?
    In my head I just need to get longer 8mm Metric lead screws and C-Beam Rails. All other parts will fit :D Extends this by a inch or 2 then it will cover my needs :D
    is this correct ? or I am way off ? TIA
    #312 Inge, Jan 4, 2020
  13. Rick 2.0
    X yes, Y no. X is as simple as ordering a 500mm C-beam and a matching screw. Y is limited by the throat depth between the router bit and the rear column. So making the axis longer really does nothing to increase the capacity. Increasing the throat depth by building out the upper assembly with some extra plates is possible but it leads to more flex in the rear column and thus reduces the quality of the output. When you start trying to stiffen the column, you realize you've created a monster...
  14. Inge
    Inge New
    Thanks for the informative feedback :D
  15. Sam Brenneman
    We tested my build, and found that the Z axis was not engaging the limit switch in time to prevent crashing. The solution was to attach a little pad of neoprene to the bracket, nice and clean, and that it that. It's my seventh machine build, the first six being some cranky and delicate robot arms. This was more fun, for sure. pad for mini mill.jpg
  16. Yanou Fishel
    Was just wondering, is it possible to use a smaller Z-plate to win some machining height? Perhaps something with wheels on the in- and outside to increase stiffness?
  17. Rick 2.0
    The Cbeam XL gantry plate is a fairly simple drop in. You also have a machine fully capable of machining whatever suits your needs. The only issue with the inside wheels is that they conflict with the lock collar on the lead screw which reduces usable distance.
  18. Yanou Fishel
    I've decided to add a Cbeam XL gantry plate :) Now for ordering and finishing up. I saw they're used on the LEAD, C-Beam,... machines, so it would seem to be stiff enough. Should also give me some more Z-working height without greatly reducing stiffness of the column
  19. Yanou Fishel
    Whilst building the minimill (or rather the enclosure it's going to sit in) after I've mounted the mill to a thick steel slab, I noticed one wheel on the Y-gantry plate seems out of allignment causing the whole X-axis to wobble about 0.5mm. Anyone know any (quick) solution for this? Not yet looking to get into linear rails as I'd like to cut the plates for them myself :)
    bagelmaker likes this.
  20. MatthewWeems
    Hello,
    Just wondering what happened to the firmware settings list for the minimill?
    It used to be posted on the product page.....
    Any help would be great.
    Please help,
    Matthew
    #320 MatthewWeems, Aug 19, 2020
  21. Peter Van Der Walt
    Openbuilds Control > grbl settings > select MiniMill from the drop down menu. Click save, click reset.
  22. Yanou Fishel
    It's still there under the "Spoiler: Standard Settings and Misc" button
  23. MatthewWeems
    Ok, thanks, hadn't gotten that far yet, I was planning on using Repetier firmware because I already have several ramps boards and I'm using as a 3dprinter. I'll download the app and get the settings. Thanks, Matthew
  24. VanAcker
    VanAcker New
    I really need the machines assembly manual. Please help
  25. Peter Van Der Walt
    Go to OpenBuilds MiniMill
    Scroll down about halfway to "Video Build of the Minimill: Jump in and when you complete this easy step by step build-along video you will have an awesome 3 Axis CNC Mini Mill for your Desktop"
    Click the Play button on the video and follow along step by step
    MaryD and Mark Carew like this.
  26. Marcin Miszewski
    I almost finished my build of MiniMill with few tweaks made by me. Should be a little bit more solid. 0.8kw router with VFD a2. Box with electronic fully designed by me and 3d printed.
