OpenBuilds LEAD CNC
Discussion in 'CNC Mills/Routers' started by MaryD, Nov 20, 2018.
  1. Jdubster3d
    Sorry i tried searching but didnt see anything, has anyone come up with a way to attach the spoil board without have to be underneath it? Thanks again for any info
  2. Jdubster3d
    Also, sorry for all the questions just trying to get everything dialed in now, I built an enclosure but the bottom of it(where the Lead sits) isn't perfectly flat, i built it out of a 3/4" piece of plywood. I am using the rubber feet from the openbuilds part store but not all feet are touching(when i assembled the machine i assembled it on our granite counter top so i know it was assembled flat). Has anyone used any adjustable rubber feet to take out the unlevel surface or should i come up with a way to build a perfectly level platform to set the machine on?
    Thank you!
  3. Jdubster3d
    please let me know if i should be posting any of these questions in the general forum, thanks
  4. Giarc
    I use the drop in t nuts. Drop In Tee Nuts
  5. Nitehawkhp
    I'm having my 14-year-old grandson help me build the Lead Machine; in an effort to show him there a other ways to spend free time away from the black hole of video games, watching YouTube, and glued to the cell phone. However, in my haste to cut the 20x40x1000mm V-Slot, one of the 962mm pieces ended up being cut at 959mm, 3mm short of the required length. Can the machine be built using the 959mm V-Slot and trim the correctly cut, 962mm V-Slot to match the shorter 959mm V-Slot?
  6. Stumpy
    Stumpy New
    I am probably the wrong person to try to help anyone but the answer I believe is yes. You will need to make sure the lead screw doesn't extend too far out as to be caught in clothing, etc. However, if it does, 3 mm is not much to cut off a 5/16" (8mm) rod.
  7. Nitehawkhp
    Thanks for your response. I'll give it a try.
  8. Jdubster3d
    Sorry for the late reply, thank you for the help. So how do you locate the t nuts from under the spoil board? Do you use the machine to measure out the locations of each drop in t nut then drill the holes?
  9. Nitehawkhp
    I'm building the leads machine and have a big problem with my X-Axis. I'm trying to adjust the wheels on the C-Channel, and one of the wheels will not adjust to the proper pressure against the C-Channel. In fact, the wheel will not come in contact with the channel. I had no trouble adjusting the two "Y" channel's or the "Z" channel, but one wheel will not touch the channel. The other wheels on the "X" channel adjust fine.
    I have reassembled the "X" Axis carriage twice, changed the eccentric spacers and am still unable to adjust the area properly. Do you have any suggestions on what I can do to fixt this situation? Is it ok to contact you directily like this?
    Thanks in advance for any help you can provide.
    Rod
  10. Stumpy
    Stumpy New
    Can you take a picture of both sides? That way I might be able to see something you don't. It is so easy to look at something for so long and never see the wrong thing that is the culprit.
  11. Rick 2.0
    Sounds like a bad plate. Contact the shop at http://support.openbuilds.com/support/home or use the Contact Us page and they will take care of you.
  12. Gofertpc
    Gofertpc Well-Known
    Just received my Lead Machine parts from FedEx. Still working on my table so the parts are going to have to sit for a while. If the packaging is an indication of the quality then I'm in very good shape. Both boxes are extremely well packaged and tight with extra cardboard padding on the corners. So excited to get this build going. I have a smaller format CNC from another vendor that I am really quite happy with but needed the larger capacity the lead provides. I will keep the smaller one and use it for my laser work.
    Mark Carew and sharmstr like this.
  13. Gofertpc
    Gofertpc Well-Known
    Ok I've watched all the install videos and I have put a similar one together before - only two things I've noticed in the main build video to watch out for - install the light ring while installing the router mount so I don;t have to disassemble it later to add the light ring, and run the router cord into the drag chain when doing the wiring. Any other gotchas you wish you had done first? I do plan on using lock-tite blue to secure the screws - especially the motor mounts.
  14. Peter Van Der Walt
    Just watch out for this one... Mains cable especially a router (Motor, lots of EMI) right next to logic level cabling (Limit switches etc) can cause all kinds of odities. EMI from the mains cable makes its way into the other cables, and on to the controller
    See Electromagnetic interference - Wikipedia
    Gofertpc and sharmstr like this.
  15. Gofertpc
    Gofertpc Well-Known
    Here is the small parts box - extremely well packaged
  16. Stumpy
    Stumpy New
    Where do you recommend the router power cord be run?
  17. Peter Van Der Walt
    Whatever works for you :)
    Some suggestions:
    - Add a second cable chain on the other side
    - Hang router power from the ceiling
    - Use Xtension Limit Switch Kit for their EMI immunity
    as long as theres some seperation (distance) it helps a lot
    PS: Same goes for stepper motor wiring, seperating that from limits and other logic wiring (such as USB, etc) is also a good idea
  18. Stumpy
    Stumpy New
    I am using the limit switches provided by Open Builds. I am a tad bit confused about the stepper motor wiring and limit switch wiring to be separated but yet run through the same cable chain?
  19. sharmstr
    FWIW - I added an extra piece of extrusion to my Y axis vertically. At the top I added an extra L bracket. I have my router power cord and my vacuum hose connected to the bracket with a zip tie. You can see it here (although in those pictures I was using a piece of wood instead of extrusion): Shawn's Workbee 1510
  20. Peter Van Der Walt
    If you get false triggers you'll be removing them from one cable chain (;
    Of course "dont fix it if it isnt broke" - different environments, etc. Like I said above:
    Didn't say "Definately do it" (;
  21. Stumpy
    Stumpy New
    Thanks for the answers. I think I have the idea now.
  22. Gofertpc
    Gofertpc Well-Known
    Extra parts ordered before I begin assembly. Just waiting on the black box controller and some small parts to secure the machine to the table I'm currently building for it.
  23. B.andrewsmith
    In regards to the EMI questions- I've used metal braided sleeving on 2 machines. It worked well on the LEAD machine because I was able to remove the wire harnesses on the OpenBuilds pre-cut wire lengths and feed through the sleeve, then cut the sleeve to length with standard scissors. Everything still fit in the drag chains correctly. I havent had any detectable crosstalk or EMI like events.
    Metal Braided Sleeving | EMI Protection
    Its described as 'superior' for EMI protection, flexibility etc. I bought from Electriduct (candy store for cable management products) but there are plenty of other options on Amazon. It can be pricey but it was still cheaper than the 4-wire shielded cabling I have used in the past. I ran all 4 stepper motor wiring and limit switches through. You could also sleeve your router wiring with it, I have 2 of the dewalt 611s and the main line in can be easily disconnected and then reconnected after.
  24. zuzux
    zuzux New
    is it possible to fit 80mm spindle water cooled 1.5kw or 2.2 on this one ?
    bee have some 3kg limit how i read
    thanks
  25. Rick 2.0
    There is no significant structural difference between this system and the WorkBee.
  26. Dean Thompson
    Has anyone developed a solution for using two Y axis limit switches to square the x-axis to the y? I can envision a couple of different ways to do it, but before I embark on any I thought I would ask here.
  27. sharmstr
    The only real discussion I've seen about it lately is here: GRBL Auto Square
    Auto squaring is not machine specific. Its controller and software specific. I'm assuming you are using a grbl based controller so that's why I picked the link above.
  28. Peter Van Der Walt
    However mechanically square (built it well) is easier and better :)
  29. Gofertpc
    Gofertpc Well-Known
    Have all my parts after receiving my blackbox and upgraded limit switches in the mail today along with a few spare t-nuts and L brackets and screws to mount the machine to the table I hope to finish up tomorrow and then it's time for assembly.
  30. gregers05
    gregers05 Well-Known
    FWIW I have all of my cables ran together and havent had any EMI issues. Might pop up later or maybe I got lucky, but I hate wires, so having them all together nice and clean helps my OCD.
    I would also double check location of limit switches. The build videos tell you to put them at X0Y0 (bottom left), but apparently you really want them at top right?
    Check and double check to make sure everything is as square as possible throughout assembly
