Openbuilds interface gets stuck sending job.
Discussion in 'Interfaces' started by Ethan Maloy, May 23, 2024.
  1. Ethan Maloy
    I got my interface set up today to run a job so that my laptop would not be tied up for 6 hours on the job. After some issues with the naming system and learning has the interface does not like having folders within I was able to open my g-code files and click run, from there the interface gets stuck “sending” and does not run the job.
    I can run the job from the control software on my laptop, but I have noticed that when I reinstalled the software on his computer, I have the issue that when I lot run the CNC does not run right away, I have no pause and resume job. After hitting resume job the machine runs without issue.
    I assume these two issues are connected, however I do not know how no fix them. Any help is appreciated!
    Machine: Lead 1515
    Controller: x32
    Firmware: 1.58 (latest available as of this morning)
    Control Software: 1.0.374
  3. David the swarfer
    please upload your Gcode file so we can check it
