OpenBuilds-Fusion360-Postprocessor
Discussion in 'CNC Mills/Routers' started by BrandonTurcotte, Jul 12, 2020.
  1. BrandonTurcotte
    Hi folks, have anyone had any luck with the OpenBuilds-Fusion360-Postprocessor V1.0.16? Fusion does not like it. I tried manually debugging the various errors it returned but no luck.
    I am currently using an older swarfer version, but was hoping to an upgrade.
    Thanks!
    It works for me, what errors are you getting? Fusion up to date?
  3. BrandonTurcotte
    Thanks Peter for quick response, long time follower first time poster :)
    Fusion 2.0.8609
    Fusion seems to be taking exception to some formatting in the cps file? The first few lines take be to things like >>>>>>> HEADER, the md5 lines, etc. I've fumbled through clearing those, then Fusion started getting into structure {} missing, etc.
    Seems to have a bad Git merge. Will fix on Monday, thanks for the heads up.
  5. BrandonTurcotte
    Thank you.
    Reverted, give it a go and let me know if you have any issues
  7. JoelW
    JoelW New
    So I am using the latest version of Fusion 360 and wanted to know if I should use Open Builds post processor or the one provided with Fusioh 360
    OpenBuilds one if the rest of your toolchain is OpenBuilds software and hardware
    sharmstr and Alex Chambers like this.
