OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    I'm going to tag in @Jason Moore - as he just posted a build the other day using the Door input as a Plasma THC Lead1500 Plasma Table - and he may be able to point you in the direction of how he modified the default Grbl behaviour.
    David Stockman likes this.
  2. David Stockman
    Great, thank you for the support!
  3. FlatBaller
    You should use the G04 Dwell command in your gcode.
    you can specify a time to wait if you are doing a spot weld, or just a delay if you want to move the axes while arcing after an initial puddle is made.
    G04 G-Code: Pause / Dwell for Precise CNC Timing
  4. Jason Moore
    I just saw that I was tagged, did you get your automatic resume figured out?
  5. David Stockman
    Hi, uhm no. Im having a bit of problem to make the door sensor input pause and resume the ongoing job. As of now it does the feed and hold thing and I have to manually press "Resume job" after the weld is done. Did you have a solution to this? Thank you for the support!
  6. David Stockman
    That is a solution that could work if I dont manage to get the door sensor input to work as I hoped. Thank you for your answer!
  7. Jason Moore
    Which firmware version are you running?
    There a few you can reflash. In firmware I switched door open pin with resume pin. Then connected my torch height controller resume output to the black box door open terminal. I also optoisolated my THC from BB because it runs at 24v and BB is 5v.
  8. David Stockman
    Ah ok, so I have to rebuild the software to a .hex file and reflash the firmware through Control? Is the door input then acting like a pause/resume pin? So for example, if door input/resume pin is 5V job pause and 0V means resume job?
  9. Peter Van Der Walt
    Refer to the comments in Grbl's config.h to learn more:
    grbl/config.h at bfb67f0c7963fe3ce4aaf8a97f9009ea5a8db36e · gnea/grbl
    and
    and also
  10. Jason Moore
    Yep
  11. Peter Van Der Walt
    Thanks for tagging in Jason - and if i re-read your Build, you aren't using the input as DOOR at all, you were redefined the pinmap grbl/cpu_map.h at bfb67f0c7963fe3ce4aaf8a97f9009ea5a8db36e · gnea/grbl swopping feedhold (default pin used for DOOR too) and Cycle start. You do a feedhold command after triggering the plasma? Grbl v1.1 Commands · gnea/grbl Wiki then rely on the THC to send the cycle-start signal (thus not using the pin for both as the OP wants to, you mix software based feedhold with hardware based resume?
  12. Jason Moore
    Correct. In my fusion 360 post I insert an M code forfeed hold after fire command is issued and then my THC sends back a resume signal to BB modified door pin terminal (modified in firmware to resume). Then BB resumes cut movement as normal.
  13. Peter Van Der Walt
    Good solution! Thanks for sharing!
  14. StigLindberg_
    Hello everyone.
    I have a wish for a function that I wish existed in the Openbuilds controller software.
    I would like a function when you right-click on the coordinate in the Gcode editor that you would be able to mark the coordinate in the gcode and right-click with the mouse and you would then be able to select "Go to the coordinate" so that the software automatically takes the coordinate and adds it to the gcode terminal just like the function that is already there called simulate from number, only that it does it live. Yes, I am well aware that it can be dangerous, but I use my cnc milling machine on a daily basis as a form of automation machine where I mill the surface of a plastic object and therefore I cannot simply transfer a file from e.g. fusion360 the plastic item may differ in size and the way the item has settled after it has cooled.
    I have tried to make a picture of what I think, it is added below.
    A very good day to all.
  15. Peter Van Der Walt
    Thanks for the suggestion!
  16. David the swarfer
    I think a better way is probing so you can set the WCS correctly from what you have and then run the Gcode relative to that WCS (or even more than one).
    something like this (yea, I know we cannot do the math in the gcode like that in GRBL, which is a pity)
  17. StigLindberg_
    I apologize for not explaining myself more clearly, what I mean is that I want a function so that you can go from step to step back and forth in gcode live so that the machine can be moved from step to step.
    At the moment, you can just mark the line in gcode and select copy and insert it into the serial console and then the machine runs to that coordinate. But it could be easier if you could just right-click on the line number and then select go to this line and so the machine moves there without having to post the line in the serial console manually.
    In the company we have Yaskawa MH50 robot arms there can jog to step by step.
  18. sharmstr
  19. Peter Van Der Walt
    It might be buggy with 360deg circles, but do post a sample file in a git issue, we can take a look
  20. David the swarfer
    Most sources I have seen agree that using full circles is generally bad and will cause some problems on some controllers.
    I have also seen R format arcs do very weird things with > 1/4 circle arcs. Which is why we avoid R format.
    That is why most posts do not output full circles, our Fusion360 post will linearize full circles and SketchUcam outputs no more than 1/4 circle arcs (it can do full circles, there is a hidden non-user option, but don't, just don't)
  21. sharmstr
    Yep. But its for a macro that i'm writing for tracing parts. The code will eventually be converted to a dxf.
  22. Bikram
    Bikram New
    Using Openbuild control software to run my 3018, amazing software and G-code editor.
    One thing I miss is to show completed path in different color rather than show all in red.
    anyone know how to turn this on openbuild controller?
    dJOS_500 likes this.
  23. ADClark
    ADClark New
    Quick question about steps/mm in OpenBuilds Control- when a default profile is loaded (GRBL Settings -> Load Default Settings), does the default profile apply defaults for steps/mm? I have a LEAD machine and just reloaded the default settings- after doing so, I noticed that the steps/mm values for X and Y axes are identical to eachother, but the steps/mm value for the Z axis is different from X and Y. Are these default values that have been loaded? And if so, why might the Z axis default be different than X and Y?
  24. Peter Van Der Walt
    Yes, as the profile should be used for initial setup - it sets all values to sane defaults.
    After initial setup, you can tweak away at it (all values are conservative) - and then use the Backup Settings button to keep a safe copy if you need to reload it later on.
    Our profile sets X, Y and Z steps per mm as 199.1 : OpenBuilds-CONTROL/grbl-settings-defaults.js at master · OpenBuilds/OpenBuilds-CONTROL
    If its different, it was changed after loading the profile (or if you forgot to click Save, ran calibration wizard, edited the field accidentally etc)
  25. ADClark
    ADClark New
    Got it, thank you!
  26. sharmstr
    No reason to be rude. For issue 1: When the 3D viewer system is disabled, there is no 3d viewer tab. Please reinstall and verify.
    3D viewer disabled
    3d viewer tab not displayed and message in serial console.
    With 3d viewer enabled
    Peter, I can confirm issue 2. File open doesnt remember the last folder you opened a file from. I believe its defaulting to the last folder I opened from before I upgraded. I'll do a test by reverting to previous version, open a file from a different folder than it is now, then update. I'll let you know how that goes.
    Cant confirm issue with switching themes and ad going into full screen. Works fine for me. Takes 3 seconds to switch. Here's a screen recording
    Alex Chambers likes this.
  27. sharmstr
  28. Peter Van Der Walt
    Thanks, we did upgrade version of Electron in backend - possibly they changed some behaviour. Thanks for the report
  29. sharmstr
    Seems to work ok when running from a browser window localhost:3000
  30. jeffmorris
    jeffmorris Journeyman
    Is OB Control Software supposed to download new version automatically and ask me if I wasn't to upgrade?
