Openbuilds control software and gerber files
Discussion in 'CNC Mills/Routers' started by SoRKos, Oct 13, 2020.
  1. SoRKos
    SoRKos New
    Hey everyone!
    I am thinking of purchasing the CNC LEAD 1010 milling machine, but i need to be sure that i can mill PCB's.
    I believe that the controller and the motors are sufficient enough for pcb milling, but i came across with some problems concerning software.
    I use KiCad to design pcbs and i created the gerber files needed.
    Firstly i want to upload gerber files to the Openbuilds control software (web-based) in order to convert them to gcode files.
    I saw that this is possible for the Openbuilds control software, but during a "test" run i made, i failed to generate the needed gcode files.
    So my first question, is it possible to use the Openbuilds control software to mill pcbs with the LEAD 1010?
    Do i have to use another software instead? FlatCam for example? Or it doesn't matter which software i use as long as i get the needed file extensions?
    The second question concerns the autoleveling feature in order to compensate the warp of the copper board.
    So i saw some techniques (BLTouch, conductivity using alligator clips) to level the CNC with the copper board warp. Are those those techniques compatible with the Openbuilds control software?
    Can i use the XYZ Probe plus for mesh leveling or i have to use BLTouch or the conductivity technique?
    Any resource or link or comment will be helpful at this point.
    Thanks!
    Technically, CONTROL is just a Host, you may be referring to OpenBuilds CAM :)
    CAM has limited Gerber support (Tested against Eagle) so can't say for sure that the ones from KiCAD will work
    But keep in mind OpenBuildsCAM is a very beginner orientated CAM, so if you want to do it more often, there are many other CAM applications
    As explained in docs:software:overview [OpenBuilds Documentation]
    So in your example, for processing PCBs, you also again have a lot of choice to pick one that works best for you:
    I like FlatCAM FlatCAM: PCB Prototyping CAD/CAM a lot (i see you already know about it) for example, but also checkout PCB Milling - RepRap (Any workflow that support Grbl 1.1 can be used)
    Mesh levelling is not in CONTROL yet (planned feature though - see Z probe - warp compensation · Issue #62 · OpenBuilds/OpenBuilds-CONTROL ) , but again, ANY grbl host can connect to it, so you instead of CONTROL, you can use whatever Grbl Host application you like, which may have Levelling (Chilipeppr for example? )
  3. Giarc
    The LEAD 1010 will work great. I use Flatcam for generating the g-Code and Estlcam for the surface probing prior to milling. Estlcam is not free($59), but it has great probing features and other things I like. I also like the interface and the fact I can use an box controller to jog the machine around.
  4. David the swarfer
