Hi, I had an accident and my Arduino nano with grbl died while connected to OpenBuilds Control software. I left the software open, but because I did some jobs prior to the accident, the logs on the software are not long enough to retrieve the grbl config that outputs when you connect it. I bought a new Arduino nano and I have to configure the same (steps, directions, etc). Can I recover the config from OpenBuild Control software? I can not find the logs file anywhere, and in the software GUI I can not go far enough on the logs. Any idea? The GUI is still open from last time I connected to the grbl. Thanks.
Restore your last good backup. If you did not take a backup (CONTROL > Grbl Settings tab > Backup Settings button) you'll have to reconfigure by hand.
Thank you for the fast answer. I did not take a backup, my mistake... So it is impossible to get a longer log (file somewhere?) so I can view the settings it outputs when machine is connected right?
