Openbuilds CAM incorrectly importing DXFs
Discussion in 'CAM' started by ion529, Jul 22, 2021.
  1. ion529
    ion529 New
    I'm having a bit of a strange problem where when I open a DXF file in open builds CAM and it seems to import the wrong portion of a partial circle such as a fillet.
    I've attached the images of what I mean below. I originally drew the shape in SolidWorks and tried to import it. When that didn't work I tried AutoCAD and Fusion 360 but the DXF files they were generating were also causing this problem.
    Is there a specific supported CAD program? I would use the Fusion 360 CAM but the openbuilds one is just so much quicker and simpler.
    Export as / convert to DXF R14 Polyline: See docs:software:file-errors [OpenBuilds Documentation]
    Make all entities "polylines" - most often the command is called Explode or "to polyline", depending on which CAD you use. Convert your splines, arcs, etc to polylines for max compatibility with all CAMs
    Alex Chambers likes this.
  3. ion529
    ion529 New
    Thank you, worked perfectly.
