OpenBuilds ACRO Laser System
Discussion in 'Laser Cutters' started by Mark Carew, Sep 12, 2017.
  1. Peter Van Der Walt
    Duplicate, replied via PM too:
    "If by toolpaths you mean the G0 moves, then Grbl is improperly configured. Checkout gnea/grbl (NB set $32=1)"
    With laser mode enabled, G0 moves = laser off, G1 moves = laser on with whatever S value was last set.
  2. syl
    syl New
    @jake1223 are you using an SVG file to create your toolpaths from?
    Depends on:
    - belt tensioned properly (not too tight)
    - Wheel tension
    - Which drivers, and what current
    - Supply voltage
    - Acceleration Settings
    - Additional weight (cables, laser, etc)
    +- 6000mm/min in stock config
  4. jake1223
    jake1223 New
    Right now I am just lasering random images from google to get everything situated, the files are usually jpeg
  5. syl
    syl New
    Syl, his Grbl settings is the problem
    Rastering bitmaps is fine (; no need to convert
    See my earlier post:
  7. jake1223
    jake1223 New
    I ran a few projects after I changed the settings and it ran great, but now when ever I try to laser any design the laser will only work on straight cuts and will turn off when it hits curves or any other movements other than straight. Any ideas?
  8. jake1223
    jake1223 New
    I tried to run the machine with laser mode disabled and it will work, but as soon as laser mode is enabled it will mess up again
  9. Peter Van Der Walt
    laser Mode has to be ENABLED.
    Can you post a picture of what happens?
    Add the GCODE and any other files to help track your issue
    Post your Grbl settings too
    Where are you generating GCODE? Settings on the application as well
  10. jake1223
    jake1223 New
    while the x axis is moving in a straight line it will run, but as soon as Y axis engages for a curve or any other movement the laser will cut out
  11. jake1223
    jake1223 New
    The Gcode is being generated using the openbuilds generator, as well as the controller
  12. Peter Van Der Walt
    :) waiting on those
  13. Peter Van Der Walt
    Sure your wiring doesnt have a break that disconnects when Y moves (yanking on the wire to the laser module maybe)
  14. Shearder
    Shearder New
    Hey guys
    are there fusion 360 files for this? I want to make a custom "bench" and draw it with the ACRO fils so any customisation i want to make is done in one plan.
    tnx in advance.
  15. Peter Van Der Walt
  16. Shearder
    Shearder New
    AWESOME thanks a mil!
  17. Shearder
    Shearder New
    Whatever i add or change i will share back here :)
    Are you South African by any chance?
  18. Peter Van Der Walt
    Yip :) i am. Live in Beaufort West (; (Previously Potch, Centurion, Ballito as well)
    #468 Peter Van Der Walt, Mar 22, 2019
  19. Shearder
    Shearder New
    AH LEKKER!!!! I am in Midrand. Gauteng!
  20. Peter Van Der Walt
    Stop by for a beer if you ever drive down
  21. Shearder
    Shearder New
    now THERE'S a plan!! Thanks :)
    If you are in Midrand the same - though i may not have beer but a LEKKER DOP will still be available!
  22. Peter Van Der Walt
    Klippies en Coke sal ook werk! Lol!
    (ok enough hijacking the thread, sorry you all!)
    Shearder likes this.
  23. Kane49
    Kane49 New
    Hey im current looking for a fast XY Gantry for my P&P Application and the ACRO System caught my eye.
    Iam wondering how fast an Omega Drive Y Axis can move, does anyone here have solid data on the maximum feasible speed in mm/s?
    Positional Accuracy during a move isnt important
    #473 Kane49, Apr 4, 2019
  24. Shearder
    Shearder New
    NOTHING wrong with Klippies en coke hahaha, NIKS NIE!
  25. Peter Van Der Walt
    Cant say about the odrive, untested config, maybe ask them?
    Keep in mind the Acro is designed for low weight, low stress applications. If the odrive accelerates like they market it, it might crack acrylic plates...
  26. Kane49
    Kane49 New
    Ah small misunderstanding here.
    Omega Drive is simply the Belt configuration with the Pulley between the 2 Wheels ( cuz it looks like this Ω ) which Acro already uses.
    And im wondering how fast that configuration is able to move the gantry
  27. Scotty Orr
    Scotty Orr Journeyman
  28. Kane49
    Kane49 New
    Omg its literally on the same page lol, thanks for telling me !
  29. Alan L
    Alan L New
    Just joined the rank of laser users today. Parts are on the way. Ordered the ARCO 20 x 20 and the Jtech 2.8w laser setup. I can go bigger later if I need to. Light duty hobby projects. I would like to put it in some sort of an enclosure. Can anyone direct me to some postings where this has been done?
    Thank you very much
    Alan L
  30. Giarc
    I am curious if you have a 3d printer? if so, I have a suggestion that would require an IKEA location near you.
