OpenBuilds ACRO Laser System
Discussion in 'Laser Cutters' started by Mark Carew, Sep 12, 2017.
  1. cathode
    cathode New
    I'd like to build the ACRO to pair with an L-Cheapo 10w. I'd like to do PWM engraving.
    Question: will the xPRO driver board and power supply (from the parts store kit) drive this laser, or is it only for the steppers and I'd have to buy additional electronics for it?
  2. pedrofernandez
    pedrofernandez Journeyman
    What is the required voltage for that module and max amp?
    cathode likes this.
  3. cathode
    cathode New
    Specs says it's 12v or 24v, but I can't find an amperage for the MK6. It's meant to run on 3d printers, so I'm guessing it's not very high
  4. pedrofernandez
    you should be ok with 24v
    cathode likes this.
  5. cathode
    cathode New
    I pulled the trigger on the ACRO - I'll put it together and verify function, then it's laser diode time.
    What software does everyone prefer to generate the gcode? I hope to do grayscale engraving and light cutting.
  6. pedrofernandez
    Can't go wrong with laserWeb is excellent
    Peter Van Der Walt and cathode like this.
  7. bekindr
    bekindr New
    Does anybody know why my laser I got from ebay doesn't seem to work with the xpro v3 board? I connected the wires properly.... I think....
    Without the PWM/Ground wire plugged in, the laser powers on via the 12v/24v out pins, but when I plug the pwm /ground wire into the spindle pin/ground pin, the laser stays off...even when I run a job via laser grbl...
  8. bubba
    bubba New
    In your gcode do you have the command to turn the laser power on? Going just from memory I believe it is m3.
    You would also need to add the command to turn the laser off at the end of the gcode. I think it's m5
    In Laserweb you can set it up to automatically insert these commands. Not sure how you do it in laser grbl.
  9. bekindr
    bekindr New
    Yeah lasergrbl automatically does it. But I tried to do it with laserweb and still the same issue. Laser doesn't power on.
  10. pedrofernandez
    can you post an image of your wiring??
  11. bekindr
    bekindr New
    Screenshot (laser wiring)
    Screenshot (xpro wiring)
  12. BNMaker
    BNMaker Well-Known
    I just bought an Endurance Laser (same guy as L-Cheapo) and all you need is a psu and his MO1 supply board @$20 : About Endurance MO1 PCB. The driver board to run the laser from external power supply - EnduranceLasers
    I bought his 5.6W kit and ordered the MO1 as well and will pair it with an Arduino-based G2Core (32-bit TinyG) with GRBL shield.
  13. pedrofernandez
  14. Ahnassif
    Ahnassif New
    Hi everyone,
    I'd like to know if the ACRO system could handle the vertical setup meaning the system would be in a stand-up position motors move in Y and Z axes ?
    Also what's the maximum weight it could handle ?
  15. cathode
    cathode New
  16. omar411
    omar411 New
    hello sir i built the full machine but i can't connect it to the arduino how could i do that
  17. BNMaker
    BNMaker Well-Known
    More information needed - what its this 'arduino'?
    Can you not connect it physically to the wiring for the steppers and microswitches. Or can you not connect it to a computer? Or can you not connect it to an app to drive your job?
    I can't connect my car to my washing machine. Go figure.
  18. omar411
    omar411 New
    the wiring is correct i can't adjust the setting of grbl and i can't know the correct pins which the order are sent to . i want to connect the steppers to Arduino directly with out cnc shield
  19. pedrofernandez
    How you can connect your car tires to the engine without a differential or transmission? You need at least stepper motor drivers sir
  20. omar411
    omar411 New
    of course i hava the drivers
  21. pedrofernandez
    witch ones? can you send a photo of it to see if i can help you?
  22. omar411
    omar411 New
    i have the drivers and i connect the Arduino like this photo i have laser web app and grbl
  23. omar411
    omar411 New
    this is the driver
  24. omar411
    omar411 New
    and this is the app which i use . i have no problem in wiring my problem in grbl setting and how can i make this app read the machine
  25. pedrofernandez
    First be sure tht your have the current arduino usb drivers installed in your computer after that go to comms, machine connection to usb, select the card com port, baudrate 115200 then press connect
  26. omar411
    omar411 New
    When i do that it told me not supported firmware the machine is disconnected
  27. pedrofernandez
  28. omar411
    omar411 New
    I think that grbl is not installed correctly can you tell me how to install it on arduino because i am already using this version
  29. omar411
    omar411 New
    Please tell how to set it in arduino corrrectly and i have my machine grbl setting from the site here how to install it on grbl
  30. pedrofernandez
    go here
