Openbuild XYZ Probe help
Discussion in 'OpenBuilds Forum Help' started by David Fong, May 15, 2021.
  1. David Fong
    I have the Openbuilds XYZ Probe and I am having a problem with the Z axis when probing. When I probe the Z axis (in automatic or just the z) it touches the touch plate and then moves up 14mm. Then when I try to "goto 0" for the Z it does not come close to the material. I manually move it to the material and it went to 14mm to -29.33mm before it touches the material. Am I doing something wrong here or can someone offer some advice to resolve this? It also thinks my endmill is 2.84mm but it is a 3.175mm endmill.
    It does look like my X and Y is correct. Just the Z.
    Do I need to calibrate it somehow?
    Wizards and Tools > Calibration yes
  3. David Fong
    Well, DANG!! You guys make it easy don't you. Thank You for the help. I thought it was going to be a nightmare to figure out.
