Open builds touch plate with Phoenix board
Discussion in 'CNC Mills/Routers' started by ashish B, Apr 15, 2020.
  1. ashish B
    ashish B New
    I ordered the touch plate but now I am wondering if it would work with Phoenix controller. It is grbl based and has output for probe. However the touch plate uses 3 wires and one of them is +ve . Can someone help and explain what voltage the +ve has to supply to touch plate ?
    5v will do. BlackBox has high voltage inputs so can run the probe on 5-24v but if your controller is not protected with high voltage inputs, run it on 5v.
    But it's also optional to power it, can run with Gnd+Sig only as well :)
    Will work fine with any Grbl controller.
  3. ashish B
    ashish B New
    Thank you.
