ooznest OX CNC Machine
Discussion in 'CNC Mills/Routers' started by Ryan Lock, Apr 28, 2015.
  1. Gary Caruso
    Gary Caruso Veteran
    If you don't use glue or double sided tape why even dual belt? reminded me of the Flaming Lips "She Don't use Jelly" song!
  2. Ryan Turner
    Ryan Turner Journeyman
    Nevermind.. As I've said I tensioned both belts, it works
  3. Bjorn Mikkelsen
    Bjorn Mikkelsen Well-Known
    The most important thing is that it works. But for me doing what Gary advised (putting 0.5mm under the lower belt and gluing it) made a HUGE difference in how well it runs.
  4. NeoMorph
    NeoMorph Well-Known
    I mostly loving my Ooznest OX build but while everything in packaged lovely and the cuts are perfect in quality and precision there is one thing that lets it down... and that is one of the 3D printed parts.
    It’s sharp as razor blade, nut holes have sagged and full of filaments which means I had to spend an age clearing out the mess with a Dremel. It’s like their 3D printer was on its last legs. But luckily it’s only on the one part of the drag chain. Dremel + sanding + primer and paint sorted that.
    But one thing in the build nearly caught me out. The voltmeter that was included wasn’t checked and there are hair thin wires poking out the connectors (see image attatched) that could very easily short out. I only spotted them with my reading glasses on. Now more than likely they would either trip the short detection or just burn out the first time they short... but for this much money they should have been checked better.
    But generally, bar these few niggles this build has been fun. I still haven’t finished (I’m slow because my disability limits how much time I can devote to it every day) but I am also including some custom bits that I wanted to add to my machine (like computer speed controller for the Dewalt 611 and Manual Pulse Generator). Ironically I managed to sort those out quick yet have had LOADS of trouble finding connectors to fit my 63mm flexible pipe for the vacuum system (but nothing that copious amounts of duck tape can’t fix).
  5. Ryan Lock
    Ryan Lock Master
    @NeoMorph My apologies for the issues, if you need anything we can sort you out. Which plastic part are you referring to, the y moving drag chain mount i think?
  6. NeoMorph
    NeoMorph Well-Known
    It’s the “Y Drag Chain Moving End Mount”. As you can see in the picture you can see it’s distorted and was sharp as a razor until I filed it down... but the main problem was getting the nuts in the holes as they were full of filament and getting the Dremel in there was a nightmare due to the angle of the shelf. It’s the only part that was problematic and I was humming and ahhing whether to get a replacement from you but in the end I decided it was okay until I can make one out of aluminium. The wires to the voltmeter were more worrying which is why I triple checked all the electrics but that was the only problem. It’s easy to miss in bad light.
    Buy out of everything, just one bad print and one untrimmed wire part... I’m still happy. I just rather tell people how it is, the good with the bad, and there is a heck of a load more good than bad.
  7. Ryan Lock
    Ryan Lock Master
    Hi,
    Yes that is fair enough, i prefer to know the issues so we can improve. I can send you out a new plastic part if you want. I have been checking the prints today for the same issue, so glad you made me aware.
    Ryan
  8. NeoMorph
    NeoMorph Well-Known
    That would be great Ryan... it’s silly that it’s niggling at me after everything else was so perfect but every day I come into the room my eyes immediately are pulled to look at it. Touch of OCD on my part I think heh.
    Personally I think the cause was my bad luck lately. For example last night I dropped my Kindle Voyage, bent down to pick it up and my leg spasmed due to my disability. I took one step forward automatically to stop falling over and heard CRRAAACK! Yup, £170 Kindle cracked right across.
    So yeah, thanks for the offer. I’ll take it because with my luck my fixed one will probably burst into flames and explode.
  9. olecam
    olecam Journeyman
    Hi -
    I was wondering if it would be easy to install limit switches on the new Workbee machine. Is there some space/mouting provided for this?
    Tks and best regards,
    Olivier
  10. NeoMorph
    NeoMorph Well-Known
    This may be a bonkers simple question but how do people attach their spoilboards? I’m approaching the end of my build and just realised I’ve not got any t-nuts on the top of my v-slot supports you see (did I miss a step somewhere?).
  11. olecam
    olecam Journeyman
    I had to bought some t-nuts to attach my spoil board to the frame. BTW, maybe Ryan should add a fixation kit as an option (or always include it in the shipping) in order to draw attention that it might be necessary to stock additional screws and t-nuts for that purpose? Just a thought... ;)
    Olivier
  12. NeoMorph
    NeoMorph Well-Known
    9784FB6E-79E6-487A-8F24-8D66A30CCA14.jpeg I actually had to look through the (awesome) instructions again just to realise I hadn’t missed it.
    I did however spot a funny spelling mistake... either that or I’ve got to buy a new home to be safe when using this CNC.
    I’m probably going to bolt the board to the table along with the frame. That way I know it’s solid. I made the units specifically for the CNC you see.
  13. Ryan Lock
    Ryan Lock Master
    @NeoMorph Could you pm me over your Order id and i will get it sorted. Thanks for pointing that out. I am afraid we don't provide fixations for the spoilerboard. Maybe it is something we should look into.
    @olecam Yes, the Z-Axis has threaded holes to mount them without loosing in Z Cut depth. And the X and Y can be mounted using the Limit switch kits.
  14. olecam
    olecam Journeyman
    Great news, Ryan, thanks! I'll place my order for an upgrade very soon. Is there any parts I should include for the Z-axis? Maybe a microswitch?
    Olivier
    #854 olecam, Oct 11, 2017
  15. NeoMorph
    NeoMorph Well-Known
    Even suggestions would help but for a newbie like me it was a head scratcher. I knew I needed a spoilboard at least heh.
    It’s been a slow build but I’m nearly there. Had to remove one of the waste board supports temporarily last night because I hadn’t got enough T-nuts to anchor the belts but had a load of drop in T-nuts left over.
    The electronics are taking time because I’ve housed them in a shielded case. I’ve also included the optoisolator board for the limit switches in there never liked the idea of a board sitting in the open, especially as I will be cutting acrylic. I have this image of static buildup like stroking a cat... so everything is shielded, earthed and ferrit bead protected (belt and braces approach). Will have to see if it works.
  16. NeoMorph
    NeoMorph Well-Known
    Just put the final bits together and realised that either the Ox is designed to do without the spoilboard supports or ive built it wrong because the Z gantry comes down and touches the supports WITHOUT A SPOILBOARD.
    Have I built it wrong?
    Edit: Just done some research and it seems it was built with such an area underneath the spoilboard to build in a vacuum table. I think I’m just going to put down several pieces of MDF which will bring the level up and allow full travel of the Z axis without crashing into the table. Plus it gives extra weight to the table AND means I have 5 replacement spoilboard surfaces.
    #856 NeoMorph, Oct 12, 2017
  17. Gary Caruso
    Gary Caruso Veteran
    Having to disassemble and re-assemble many times due to forgotten T-nuts is an openbuilds right of passage! So you are doing it right ;)
    NeoMorph likes this.
  18. Ryan Lock
    Ryan Lock Master
    @olecam If you buy the upgrade kit, the limit switches will be included.
    @NeoMorph The Z-Axis can each down further than the spoiler supports. Doing as you suggested is a good way to gain extra cutable depth.
  19. NeoMorph
    NeoMorph Well-Known
    Well I’ve got the bits now... just waiting for my nylon bolts to arrive.
    Got plenty to do with the unit though because I’m encasing it in a soundproof shell as I live in a terrace. I’ve got a SuperPID to control the speed remotely too so that’s helping with the noise levels. Even lets me drop it down to 5000 rpm on the Dewalt... both manual and computer control options.
    One of the first jobs I plan to do is make a Controller Panel for the shortcut keys, speed controller and the cheap MPG dial I got off eBay. Was surprised at how easy it was to get working to be honest. Am I overdoing my build... probably... but I’m as interested in building it as I will be making stuff with it and I have to say that I really loved building the Ooznest kit. It’s the clearest build manual I’ve come across in... forever and one came across one spelling mistake and one sequence oversight (mainly to do with buying the full kit as the manual was just listing the mechanicals.
    I’ve made several changes to protect the Xpro and isolate it from electrical noise. I’ve also made it fully computer controlled by the SuperPID. But ultimately I want to make it remote controlled to so that it can send me alarms when it shuts down or I can check on it via a camera to my phone and a remote fob will let me shut down the the machine like hitting an emergency stop. Belt and braces. One thing I would love to do is a home brew toolbreak detection system because if you are cutting for hours and a tool breaks and you are air cutting... well, what a waste of time.
  20. NeoMorph
    NeoMorph Well-Known
    Thanks for that Gary... I thought I was being a brain fogged numpty again lol.
  21. NeoMorph
    NeoMorph Well-Known
    8E321DF5-9009-438A-9515-44930373B2B2.jpeg Question: X and Y axes....
    It was originally my view that the Y axis was along the gantry and the long side (I have a 1000 x 750 version) was the X axis... but the wiring is opposite that.
    On most mills I’ve looked at the x axis is along the bed from left to right. Y axis is from front to back.
    It’s a minor change to the wiring and move the clone jumper from Y to X but I was was wondering why it was shipped reversed. I thought it was a fault with the electrical manual manual at first but the XPro is shipped with the default being the Y axis.
    Am I missing something (sorry to be such a niggle).
    #861 NeoMorph, Oct 12, 2017
  22. Rick 2.0
    You are correct but you have to be looking at the machine from the right direction. The photo at the top of the page shows the front of the machine with front to back Y-axis rails at the sides and left to right X-axis gantry beam across the top.
  23. NeoMorph
    NeoMorph Well-Known
    That photo is looking along the X axis from everything I’ve looked at. Yet the Ox seems to be shifted 90 degrees.
    Like I said, simple fix because all my designs on Fusion 360 are done with the X being longer than the Y or I would just leave the Ox as designed. It’s just easier to rewire the XPro than go through and change all the 3D models I’ve worked on.
  24. NeoMorph
    NeoMorph Well-Known
    Well I have got it moving... yay... but the dual motor axis (I’ve set it to X) is noisy as hell.
    I think there might be a friction problem or something because when I set it jog to 1 and tap the jog button it doesn’t move. Tap again and still no move... yet on the third tap it moves. Tap again, no move, no move, move. It moves every third tap.
    So tomorrow I’m going to see what happens when I loosen the gantry way off and see how that affects it.
