OB Interface Capabilities
Discussion in 'General Talk' started by Rink, Dec 21, 2023.
  1. Rink
    Rink Well-Known
    Good afternoon.
    I have the new LEAD 1515 up and running. Questions about the OB Interface:
    With the Interface, can I:
    1. Jog to G28 or G30 locations?
    2. Jog a specified amount or to a specific location (e.g. exactly 300mm)?
    3. Change to different work coordinate systems (G55-G59)?
    4. Connect computer through Interface?
    Or are these actions available only in OB Control on the computer?
    I looked around but didn’t see these anywhere on the buttons or menus. The Interface does have a USB-C port labeled “Computer”.
    Thx, rink.
    Not directly, but if you really need to, add a gcode file for yourself caled something like G28.gcode and inside just have a G28 command. Run it like a job would
    No its mainly designed for ease of use. Probe ideally, run from there. A probed piece of stock can handle jigs and offsets too - as you can set all that in gcode.
    You Job can include WCS commands
    No, Interface "replaces" the PC, so one or the other.
    For firmware updates
    A full blown host has more flexibility but a smart operator can do everything you need to on an Interface too. Just think of it as your walk-up-and-run tool and rethink your workflows to accomodate that.
    Think smarter to use a simpler toolset
  3. Rink
    Rink Well-Known
    Thank you.
