Nut Blocks for Custom Plate (Design Question)
Discussion in 'CNC Mills/Routers' started by Scotty Orr, Oct 21, 2017.
  1. Scotty Orr
    Scotty Orr Journeyman
    I am designing a custom "long" gantry plate for an upcoming build and have a question about lead screw nut blocks. I want to use two nut blocks on this plate, and am curious about the necessity of using the anti-backlash versus the standard nut block.
    My thinking is that I will use one anti-backlash and one standard, with the holes slotted for one of them to allow adjustment so the threads will mesh properly. Is my thinking correct, or should I use two anti-backlash blocks? (Or since I will use two, is even one anti-backlash block necessary?)
    Thanks,
    Scotty
    Standard nuts both sides should be fine.
    Scotty Orr likes this.
