novice question
Discussion in 'Tutorials' started by Roger Hughes, Feb 29, 2020.
  1. Roger Hughes
    I am preparing to build a large router table. Trying to figure out how to connect two v slot rails at 90 degree angle to each other with strong connection What part/tool/mechanism is available on the Open Build store that attaches into the end of a V rail
  2. Maybach57
    Maybach57 New
    I used the triangular edge connectors to secure each 90-deg angle and left them a little loose. Once I had all 4 corners ready, I tightened the edges.
    BTW, I had tightened each corner first and found that the movement along the Y axis was not symmetrical. This was because the angles had gotten slightly askew. So, each corner had to be loosened and readjusted.
    You can use either of these onto the ends of V-Slot (or on the internal corner)
    Cast Corner Bracket
    Cube Corner Connector
    L Bracket
    For a really strong connection, use these 90 Degree Joining Plate
    Have a read through https://hackaday.com/2016/12/14/a-how-to-in-homebrew-design-fab-and-assembly-with-extruded-profiles/ - in particular there is a section (1. Fully-Constraining Parts) recommending the use of the corner brackets and joining plates at the same time (to constrain it from both directions) (Sadly there are some broken image links in that article that no longer show up, a real shame)
    #3 Peter Van Der Walt, Apr 29, 2020
    Rick 2.0 likes this.
  4. Roger Hughes
    Thanks for the input. I now see the bigger picture. Somehow, had not found these parts
