NickEng's Sawstop Grbl interface / coding
Discussion in 'Other Software' started by NickEng, Feb 5, 2022.
  1. Peter Van Der Walt
    Cleanup your setIntervals with clearInterval when you close the dialog / stop the macro. You are spawning multiple instances of that loop (each time you open the macro as a test) and an old one is from your metric code, still running.
    In starting your macro
    var window.sawStopDROUpdateLoop=setInterval(...)
    In closing/stopping the macro:
    clearInterval(sawStopDROUpdateLoop)
    Restart CONTROL from the systray icon's quit menu to get rid of the now abandoned loops
    #151 Peter Van Der Walt, Mar 2, 2022
  2. NickEng
    NickEng Well-Known
    Ok, I think I've got it working! I am still getting an error " Please wait for machine to be Idle, before jogging" . I tried adding the if statement you suggested to wait for idle, but it didn't fix it. I am wondering if it has something to do with my button click then "clicking" the main jog button and mimicking a second click and causing the error message to appear. It seems to get hung up sometimes in the jogging state and keeps going when it shouldn't.
    Another cool feature I have thought of is a "cut list" So, the idea is you upload/type/paste/ multiple cuts (cabinet maker) there is a next button. You make a cut, press next, it goes to the next size board that is needed to be cut, make cut, click next. You wouldn't have to manually put each cut in. Much more efficient.... If you designed the cabinets in a program, you could then just take your cut list, upload it to the macro (some how) and would be ready to go!
    That was just a thought for the future....
    Here is code for now....
    var continuousJogRunning = false;
    var safeToUpdateSliders = true;
    var jogRateX = 4000
    var jogRateY = 4000
    var jogRateZ = 2000
    // Add some CSS classes
    $("<style type='text/css'>.myXpBtn {width: 160px;} .keypadBtn {width: 45px; height: 300px;} .sawStopKeypadBtn {width:130px;} .jogKeypadBtn {width:50px;}.sawStopActionBtn {width: 580px; } </style>").appendTo("head");
    // variables placeholder
    window.sawStopValue = 0.0;
    window.sawStopFractionValue = 0;
    window.currentPositionValue ;
    window.currentFractionValue = 0;
    // Update the UI <span> fields to display value
    window.updateSawStopValueUI = setInterval(function() {
    $("#sawStopValue").html(sawStopValue.toFixed(0));
    $("#currentPosition").html((laststatus.machine.position.work.x / 25.4).toFixed(3));
    if(currentFractionValue.length > 1){
    $("#currentFraction").html("&nbsp;and&nbsp;" + currentFractionValue);
    } else {
    $("#currentFraction").html("");
    if (sawStopFractionValue.length > 1) {
    $("#sawStopFraction").html("&nbsp;and&nbsp;" + sawStopFractionValue);
    } else {
    $("#sawStopFraction").html("");
    }, 50);
    window.updateLastStatus = setInterval(function(){
    currentPositionValue = laststatus.machine.position.work.x / 25.4;
    }, 47);
    // keypad button
    window.sawStopBtn = function(val) {
    var currentValue = sawStopValue.toString();
    currentValue += val;
    sawStopValue = parseInt(currentValue);
    window.currentPosition = function(val){
    // fraction button
    window.sawStopFraction = function(val) {
    sawStopFractionValue = val;
    window.currentFraction = function(val) {
    currentFractionValue = val;
    // backspace button
    window.sawStopBackSpace = function() {
    var sawStopcurrentValue = sawStopValue.toString();
    var sawStopNewValue = sawStopcurrentValue.slice(0, -1);
    if (sawStopNewValue.length == 0) {
    sawStopNewValue = "0";
    sawStopValue = parseInt(sawStopNewValue);
    window.farLeft = function() {
    sendGcode("m9");
    sendGcode("G4P0.5");
    sendGcode("$J=G90 G20 X 96" + " F10000");
    window.goHome = function() {
    sendGcode("m9");
    sendGcode("$H");
    window.sawStopMoveTo = function() {
    // Calculate Decimals from fractions
    var sawStopFractionSplit = sawStopFractionValue.split("/");
    var sawStopDecimals =
    parseInt(sawStopFractionSplit[0], 10) /
    parseInt(sawStopFractionSplit[1], 10);
    var decimalSawStopFractionValue = eval(sawStopFractionValue);
    } else {
    var decimalSawStopFractionValue = 0;
    // add decimals to integers
    var sawStopFinalPosition = sawStopValue + decimalSawStopFractionValue;
    // Send move command to Grbl
    sendGcode("m9"); //unlock pnuematic cylinder
    sendGcode("G4P0.2");
    sendGcode("G90 G20 G0X" + sawStopFinalPosition + " F10000 " + "\n M8"); // move to position
    currentFractionValue = sawStopFractionValue; // save fraction value to display current position
    sawStopValue = 0; //reset value to prepare for next entered distance
    sawStopFractionValue = 0; //reset fraction value to prepare for next entered distance
    $(function(){
    $('#jogTypeContinuous').prop('checked', true)
    allowContinuousJog = true;
    $('#myXp').on('touchstart mousedown', function(){
    sendGcode("m9");//unlock
    $('.xP').mousedown();
    $('#myXp').on('touchstart mouseup', function(){
    $('.xP').mouseup();
    sendGcode("m8");//lock
    $(function(){
    $('#myXm').on('touchstart mousedown', function(){
    $('.xM').mousedown();
    //$('.xP').click();
    $('#myXm').on('touchstart mouseup', function(){
    $('.xM').mouseup();
    function resetJogModeAfterProbe() {
    if (localStorage.getItem('continuousJog')) {
    if (JSON.parse(localStorage.getItem('continuousJog')) == true) {
    $('.distbtn').hide()
    } else {
    $('#jogTypeContinuous').prop('checked', false)
    allowContinuousJog = false;
    $('.distbtn').show();
    $('#confirmNewProbeBtn').removeClass("disabled")
    // Create the User Interface
    Metro.dialog.create({
    title: "Saw Stop Macro",
    width: 'auto',
    content: `
    <span class="display1">Enter Distance:&nbsp;</span>
    <span class="display3" id="sawStopValue">0</span>
    <span class="display3" id="sawStopFraction"></span>
    <span class="display1">&nbsp;inch</span>
    <span class="display2">&nbsp;&nbsp;&nbsp;</span>
    <span class="display1">&nbsp;Current Location:&nbsp;</span>
    <span class="display3" id="currentPosition"></span>
    <table class="table compact">
    <td>
    <table>
    <tr>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(1);">1</button></td>
    <span class="fa-layers fa-fw">
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(2);">2</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(3);">3</button></td>
    <td></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('1/16');">1/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('1/8');">1/8</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('3/16');">3/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('1/4');">1/4</button></td>
    </tr>
    <tr>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(4);">4</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(5);">5</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(6);">6</button></td>
    <td><button class="button alert x large rounded outline m-0 " id="myXm" style="width: 160px;" data-role="ripple" data-ripple-color="#e21b1b"><i class="fas fa-arrow-right "></i>JOG RIGHT</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('5/16');">5/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('3/8');">3/8</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('7/16');">7/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('1/2');">1/2</button></td>
    </tr>
    <tr>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(7);">7</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(8);">8</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(9);">9</button></td>
    <td><button class="button alert x large rounded m-0 " id="myXp" style="width: 160px;" data-role="ripple" data-ripple-color="#5de21b"><i class="fas fa-arrow-left "></i>JOG LEFT</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('9/16');">9/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('5/8');">5/8</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('11/16');">11/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('3/4');">3/4</button></td>
    </tr>
    <tr>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="farLeft();">FAR LEFT</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBtn(0);">0</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopBackSpace();"><i class="fas fa-arrow-left"></i></button></td>
    <td></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('13/16');">13/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('7/8');">7/8</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="sawStopFraction('15/16');">15/16</button></td>
    <td><button class="button outline xlarge m-0 sawStopKeypadBtn" onclick="goHome();">HOME</button></td>
    </tr>
    </table>
    <table>
    <td><button class="button outline large m-0 sawStopActionBtn alert" onclick="sawStopValue=0; sawStopFractionValue=0;">CLEAR</button></td>
    <td><button class="button outline large m-0 sawStopActionBtn success" onclick="sawStopMoveTo();">MOVE TO</button></td>
    </table>
    actions: [{
    caption: "Exit Macro",
    cls: "js-dialog-close alert",
    onclick: function() {
    window.updateSawStopValueUI = clearInterval (function(){})
    window.updateLastStatus = clearInterval (function(){})
    printLog("Saw Stop Macro Exited")
    Thanks!
    Missing listeners for the touchup / mouseup events? Button down starts the jog, button up stops the jog. See https://github.com/OpenBuilds/OpenB...522ddaa7e671bedc7f523/app/js/jog.js#L436-L441
    Well this was a crazy learning experience for you, so take the toolset you got from this :) and move forward. Generic tips: paste lenghts as comma seperated. Split the string to an array using the js split function. Iterate the array looking at the values at index.
  4. NickEng
    NickEng Well-Known
    This sounds complicated…I assume I need to put an input box somewhere in the macro using <input> Id= and get the “input” value that is typed in by getElementById(). save the data retrieved to a string variable. Use js split function to convert string variable to an array? And I’m really lost with the “iterate the array looking at the values at index”.
    I don’t know that any of that is right…
    thanks!
    :) i'm not directly going to be able to help with that, except to encourage you to keep on learning. You got amazingly far already - you got this!
  6. NickEng
    NickEng Well-Known
    @Peter Van Der Walt well I appreciate all of the help! It has been really neat playing around with all of it. I had some time this morning, and I think I got the basics of the "Cut list" worked out following your advice. I am sure there are much better ways to do it than I did, but it appears to work. It could still use some styling and rearranging, but I think it is functional. I am going to paste below in case anyone else finds it useful. The cut list could almost be beneficial in a macro on its own. There are still other things I keep thinking of to add, but I think that will probably always happen! Again, I am very appreciative of all the help!
    Thanks!
  7. NickEng
    NickEng Well-Known
    I am still playing around with this, and I am having difficulty with the flickering of old variable data if I close the macro and open it back up. I cleared this up earlier with a clearInterval at onclick of the end macro button press. However, the intervals I added (display currentCut and NextCut for the cut list) they are in the same setInterval function as was with the original code.
    I think, I am changing the html variable with jquery like this:
    if(nextCut > 1){
    $("#displayCut").html("Next Cut: " + nextCut); //displayCut is used to know what to display in the metro.create.dialogue below the variable nextCut is what's actually displayed
    else{
    $("#displayCut").html("");
    if(currentCut > 1){
    $("#displayCurrentCut").html("Current Cut: " + currentCut);
    else{
    $("#displayCurrentCut").html("");
    I am displaying it in the Metro.dialog.create UI with by calling it within a span.
    It works great until I exit the macro and reopen it. Then I am getting a flicker that is displaying old data. I have the clearInterval Function being called when the macro is exited.
    I know you are busy, and may not be able to help, but is there a forum somewhere to ask these types of coding questions?
    Thanks!
    Don't those values only update when something happens? Like when a cut finishes and you click Next - rather than an Interval, i'd save the CPU and just update those more static views when they change (when you move to the next cut) as unlike the DRO, they don't update continuously?
    Make sure the clearInterval actually does clear it. If you accidentally allow two instances to start for example, only the last started one will clear.
  9. NickEng
    NickEng Well-Known
    That worked..... that simple, I've been struggling with it for an hour and couldn't figure it out. I am going to attempt to add a quantity to the input data box and split it twice to get the correct data. There may be a better idea, but the idea is to split the input data by separator "," and save to a variable. Take that variable and then separate it with a whitespace separator. So example, If I input (28 2, 36 1, 32.5 3) I would separate 28 2 as the first variable and separate again with (" ") this would tell me the quantity (2) needed for that length board (28"). Maybe a better way?
    Thanks!
    Was wondering how you were gonna deal with fractions - decimals are so much easier - but I get it. No comment on my end about that one - boils down to how you want to format the list, and keeping it consistent - parsing it should work out
    Did find How to parse and capture any measurement unit – JavaScript
  11. NickEng
    NickEng Well-Known
    I haven’t checked it out, but I will.
    I don’t really know how or if I am going to handle fractions. My thought was to handle them similarly to the way you did with the button presses. Maybe enter them like this:
    23-5/8 2. Where the 23 will be split from the 5/8 with the “-“ and then do the math and combine them back together. Let the white space separate the quantity.
    I really need to look at how programs spit out there cut list. It would be nice to be able to copy and paste the cut list in to the input box, but that may not be possible.
  12. Peter Van Der Walt
    Or build another Macro that has a form (; qty|feet|inch|fraction easier to fill in maybe?
  13. Phil Harris
    can this be converted to metric easily ?
