New pendant project
Discussion in 'Control Software' started by Ivo Beltchev, Jul 12, 2023.
  1. Ivo Beltchev
    Hey, everyone
    I’d like to share a project I’ve been working on for the past few months.
    It is a CNC pendant that works with the Control software.
    You can view the current status, jog the machine, run jobs, probe Z, there's tool change support, and much more.
    I’ve been using it for a couple of weeks now and it is super convenient. I only need to go to the PC to load the gcode and to view error messages when something goes wrong.
    It is fully open-sourced. You can find the software and hardware details on Github: GitHub - ivomirb/Controlinator-3000: CNC hand-held pendant for OpenBuilds CONTROL
    It is compatible with the stock Control software, however it works better with my fork, which adds an extra event for monitoring the Grbl responses: GitHub - ivomirb/OpenBuilds-CONTROL: OpenBuilds CONTROL: Download from https://software.openbuilds.com
    Mark Carew, Giarc, Mohamma393 and 2 others like this.
  2. Matt Petersen
    This is very cool!
  3. David the swarfer
    here is your answer @Evilspawn , use the Haas hardware with this controller
    Great work!
    Decoupling the core functionality / comms into an Arduino Library, combined with the Macro, would be a game changer for people to build their own, everyone always wants a little different spin on things
  5. Marcthijs
    Marcthijs New
    Hello Ivo,
    Looks very professional.
    The arduino software is not available on github?
    Best regards,
    Marc
  6. Ivo Beltchev
    Hey, Marc. Sorry for the late reply. I forgot to Watch this thread.
    The arduino software is on github. It's all here: Controlinator-3000/Source/Pendant at master · ivomirb/Controlinator-3000
    You start with Pendant.ino, which includes all the other .h files.
  7. Marcthijs
    Marcthijs New
    Thank you very much Ivo.
    Best regards,
    Marc
  8. keverin16
    keverin16 New
    Very interesting project. Does this work with 4th axis? (rotary)
  9. Ivo Beltchev
    No, rotary is not supported. It could possibly be added. You will need to find a way to fit an extra line of text, either by sacrificing some functionality or by using a larger screen. And add an extra button.
  10. Michael L Jones Sr
    I built the pendant and when I plug it into the computer it immediately displays
    Connected to PC
    Connected to CNC
    It never does anything else. Any idea what I could have done wrong?
  11. Ivo Beltchev
    Is the macro running inside OpenBuilds CONTROL? Do you get any messages in the software about attempting to connect to the pendant, and failing?
  12. Michael L Jones Sr
    Thanks very much for such a prompt reply, Ivo.
    I get a message that says Failed to find a pendant.
  13. Ivo Beltchev
    Try a different USB port. If you have the Arduino console enabled, turn it off because it might be connected to the same port. Only one application can use it at the same time. Try a different cable. Some USB cables are only for charging and don't transmit data.
    If nothing else helps, then shut down everything and try to connect using the Arduino serial console with baud rate 38400. Type the command "PEN". You should get a response "DANT". If not, something very basic is not working.
  14. Michael L Jones Sr
    Thanks again, Ivo.
    I’ll try your suggestions tomorrow and let you know what happens.
  15. Michael L Jones Sr
    Moving the USB cord to different port brought it to life, Ivo. Thank you very much for your help and for designing the pendant.
    Ivo Beltchev likes this.
  16. keverin16
    keverin16 New
    Hello Ivo
    I have a problem with probing. If i start the probing script. It travels to the Probe and stops when it makes contact. Then nothing else happens, it doesnt retract and it doesnt finish the script.
    Its almost like the pendant thinks it cannot move upwards. Do you have an idea what the problem could be? Thanks!
  17. Peter Van Der Walt
    What controller? BlackBox X32? If so, is your Firmware up to date? (Section 7.1 and 7.2 of the BlackBox X32 documentation https://docs.openbuilds.com/blackbox-x32 relates)
  18. Ivo Beltchev
    Does the probe work without the pendant? (if you use the probing functionality of OpenBuilds directly)
    Does the pendant work otherwise? Jogging, starting/stopping jobs, etc.
    What are your Z Probe settings in the pendant software? A screenshot would be nice.
    What is the log output while the probing is going?
