new issue with interface
Discussion in 'Interfaces' started by Makoto cameron, Apr 25, 2021.
  1. Makoto cameron
    Aloha
    just came across a new issue with the interface.
    boots up ok, finds wifi and connected usb
    firmware is up to date 1.47
    GRBL no connecting
    checked all involved wiring-ok
    flashed blackbox- ok
    reset interface- same issue
    hardware
    lead 1015 w/laser
    blackbox
    openbuilds power supply
    openbuilds interface
    Remembered to unplug usb cable from BlackBox?
    if its not that, check pins on connectors on cable between interface and blackbox for damage, or pulled out of connector slightly (reseat them properly)
  3. Makoto cameron
    Thank you Peter
    Ill play with the wires
  4. Makoto cameron
    it was the wiring, thanks again Peter
    Tie it off with a cable tie through the provided strain relief slots in the back panel to prevent some wear and tear :)
  6. Makoto cameron
    Great idea, thanks again
