New Blackbox has stopped communicating
Discussion in 'Controller Boards' started by Joe Geisler, Feb 14, 2020.
  1. Joe Geisler
    Hello;
    I Bought the Bulkman3D 1510 Workbee mechanical ad Electronics kis recently. assembled everything, found arduino was bad out of the box so they will send a new one once they return to work due to Coronavirus.
    Not wanting to wait and wanting a better system I ordered a Blackbox from Openbuilds and WOW what a difference, looks great, boots right up, communicates easy. started small, just testing box, then 1 stepper to verify wiring order, then all steppers, then Z Probe, (had problems finding the Z probe wizard but that was purely my error due to lack of sleep, tested Z probe and it worked perfectly. calibrated steppers, all good, did a pen test and everything worked. then about 15 minutes later while i was preparing limit switches on the bench for wiring (nothiing hooked up yet, just prepping, I heard a faint click and saw that my laptop had turned off, Completely off. I dont have sleep mode enabled and computer was plugged in. After rebooting everything my laptop will not connect to the Blackbox. multiple attempts.
    searched forums. backtracked, maybe newest wiring (probe) was causing a problem, it was not grounded or shorted. disconnected and tested, same result,
    I powered down, disconnected everything from my Blackbox, turned off computer, everything. rebooted all, connected USB, Openbuilds Control sees "FTDI USB to Serial COM3" but it will not connect. This is what I get when I turn on Control then try to connect:
    [10:35:35] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [10:35:35] [ Websocket ] Bidirectional Websocket Interface Started
    [10:35:36] [ update ] Checking for Updates
    [10:35:37] [ update ] You are already running OpenBuilds CONTROL 1.0.207
    [10:35:45] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [10:35:45] [ connect ] Checking for firmware on COM3
    [10:35:45] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [10:35:46] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [10:35:47] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [10:35:49] [ connect ] ERROR!: No supported firmware detected - you need a controller with Grbl 1.1x on it, or there is a problem with your controller. Closing port COM3
    [10:35:49] [ disconnect ] PORT INFO: Port closed
    I read the forums and rebooted everything, same problem.
    I tried a different USB cable (1st cable was brand new with Blackbox) same errors
    I tried a short blue USB cable that I received from Bulkman3D, same issue.
    All device drivers for USB ports and devices show latest drivers.
    Tried other laptop (MUCH NEWER with lots of USB ports, both 2.0 and 3.0) same result
    Any ideas or next steps?
    Staff Member Moderator Project Maker Builder Resident Builder
    Accidentally shorted V+ and GND pins on the output of the Limit switch connector?
    Also, never do wiring with things powered up! Always unplug electronics when working on it (Yes, USB is power as well)
    If you are lucky, that didn't do any permanent damage: If the incorrect limit switch wiring is still plugged in it will prevent the board from booting (as 5v rail may be shorted to gnd through a wiring mistake).
    Disconnect ALL wiring except the USB cable and test again. If it connects you are in luck.
  3. Joe Geisler
    Actually I was standing about 6ft away from the blackbox when everything happened, nothing new was connected. I was just preparing the limits and their wiring (crimping connectors, that sort of thing, nothing plugged into blackbox while working on stuff. Only had system powered up so I could use the LED light ring that is powered off the PSU and if I power down then the weight of my spindle (that I still haven't had a chance to hook up yet) pulls my Z down too far to use the light)in preperation for when I had to climb into my enclosure to install them.
    Ok, so far I have disconnected everything from blackbox EXCEPT power and still gotten same results. I will power everything down, disconnect power, reboot laptop again just to verify it isnt a latched in problem, hook up USB and try again
    Which PSU are you using?
    What exactly was connected, you mentioned limits and that is something that we see happen sometimes (if users wire C and NC of switch to GND and V+ by mistake instead of GND and SIG - as it comes up often, and you mentioned working on limits, it was the most likely cause)
    If nothing really was plugged into the limits, then work with what was, list it all so we can try and figure out happened. They go though a USB burn in test, so we need to try and find out what damaged it if it was damaged to avoid recurrence :)
    Note the difference to my request :) - disconnect power too!
  6. Joe Geisler
    OK, my computer is at the end of my CNC table next to blackbox and Mean well LRS-350-24 24v power supply that has a OB power case on it.
    hooked to the PSU was the Blackbox AND 24v LED lightright (separate connectors). Hooked to the Blackbox was the 4 stepper motors and the Z probe AND THE USB. The Z probe had its alligator clip away from the base and there is no metal nearby for them to ground to accidentally. the PSU was ON, the Blackbox was ON, the USB was connected to laptop, the OB Control was open and connected to lock steppers so Z wouldnt drift down. I was 4ft away at the side of the machine using the MDF machine bed as a workbench and the LED right as a light source. I had not hooked any other plugs into sockets on the Blackbox. I was just assembling switches to mounts and crimping connectors to wires and double checking with my multi-meter continuity of the switches so i would be sure to connect to NO on switch end and SIG and GND on the sockets that would eventually go into the blackbox. I heard a click (like a relay click or something similar) and looked over to see that my compputer had gone black, completely OFF. no other thing looked out of the ordinary.
    OK, all is disconnected from Blackbox, including power. I rebooted everything, plugged in USB and got an error;
    USB Device not recognized
    The last USB device you connected
    to this computer malfunctioned, and
    Windows does not recognize it.
    Unplugged USB then plugged it back in. This time no error, open control, it didnt show USB, disconnect, reconnect, it shows FTDI USB to Serial COM3 so i try to connect and get the same problem as before, Detect 3 ways, ERROR: No Supported Firmware detected need GRBL 1.1 etc screenshot attached, attempted connection a few times same each time.
  7. Joe Geisler
    sorry if i list with TOO MUCH detail, i know you want enough info to be able to recreate the problem if necessary. I appreciate the help and fast reponses.
    Unrelated but just for future reference, whether connected or not doesnt control stepper lock: $1=255 sets that: see gnea/grbl
    Awesome, was scared its the Bulkman one, they have surges over 60v!
    There's never such a thing as too much info! :) The more we know the better we can help you, what might not look like it relates can sometimes be an important clue
    So just before I send you over to [email protected] for a replacement, just one last test I need (about to run out for the weekend but will try and check in on you tomorrow):
    In CONTROL go to Wizards and Tools > Grbl Flashing tool: Just try reflashing firmware two or three times. Check the serial log, it will say success or fail. Maybe you had a brownout that knocked the firmware off it. If that still fails, reach out to [email protected] referencing a link to this thread please
    Thanks for your patience, was really hoping to see "something" that caused it - else its always worrying if a replacement will suffer the same fate if you don't find the cause. They do get a tonne of testing prior to shipping, so its remote that it just "broke" - always nicer to find a cause like known low quality PSU, or the old oops I shorted V+ to GND, or something telltale that can be addressed to prevent a repeat. Sadly here nothing stands out, so just be careful if you do need a replacement (if firmware reflash doesnt take)
    Lastly, as you might be taking it apart soon anyway, check the boards for any visible damage? (might still help us with post mortem)
  9. Joe Geisler
    OK, attempted flashing 3,4,5,...8 times. no joy, :( , ok, i will contact the link you provided and while i wait for them I will open Blackbox and bust out the forensic tools. ... Magnifying lens
  10. Joe Geisler
    BTW, no obvious burns, scorches, hot spots or smoke residue inso Blackbox so not sure ... I did read a post or 2 that mentioned bad USB cords though. I had already thought of that and tried the 3 I had but I also bought a brand new one (just a Wally world cheapo, only thing available locally) in case that could be part of the problem but even that didnt change the problem. Still waiting to hear back from support but it's a weekend so I assume they are enjoying the weekend.
  11. Peter Van Der Walt
    Yes, they will get back to you today for sure! :)
