New 80W LPSU & Tube seem to be under performing, ammeter reads 5mA max
Discussion in 'Laser Cutters' started by CraigF, Jan 28, 2020.
  1. CraigF
    CraigF New
    New laser and tube, seem to be underpowered.
    analog milliammeter reads a max of 5mA on a scale of 30
    tested with potentiometer set at max, min, and in between values.
    lower values on potentiometer lowers ammeter value, higher values, and even mid values max out at 5mA
    tested using laser “test” button on the LPSU, as well as a momentary push button wired to ‘L’ & ‘P’ terminals
    LPSU is 80W
    attempts at trying to cut material, prove to me its power is being limited, and not a simple malfunction of the ammeter.
    what could cause the laser to be so weak?
    incorrect wiring?
    long wire runs?
    wrong gauge wires?
    ill include a wiring diagram.
