Nema 23HS30 suddenly going in random rotations
Discussion in 'General Electronics' started by ward0n, Aug 22, 2020.
Tags:
  1. ward0n
    ward0n New
    I am using the Blackbox on a diy build and my Y axis is run by dual Nema 23 motors with the Y2 in reversed direction. When jogging the y axis, 1 motor will randomly spin in whichever direction it wants, causing the y axis to bind. I have removed the motor and ran it plugged into the x and y Blackbox plugs all by itself and it does the same. What could be going on here?
  2. Gary Caruso
    One of the four wires has a bad connection.
    Check every connection, could be a broken wire or bad solder joint, or loose connector.
    Gary
    ward0n likes this.
  3. ward0n
    ward0n New
    Thank you! Good call. Pulled all the wiring out of my drag chain and found a crease in the red and black wire. Did a quick splice to check rotation and that did it. Going to run a new wire tomorrow.
