Nema 23 stops sometimes
Discussion in 'Motors' started by DanW, Sep 29, 2019.
  1. DanW
    DanW New
    Hi
    Im experiencing some problems with Y gantry. Sometimes it just stops, shakes, or changes the direction. Ive opened the motor, no visible problems there. gantry moves easily. Its difficult to tell whether its the motor or the driver (Xpro v3.) as It occurs only sometimes (enough to ruin every job). My plan for tommorow is to use <A> driver by cloning the Y.
  2. Alex Chambers
    If it stops sometimes and reverses sometimes the first thing to check is your wiring - one loose wire or bad connection causes those symptoms. If you can't find an obvious fault at one end or the other of your stepper wiring it is worth replacing it - sometimes the fault is invisible within a crimp connector for example.
  3. jeffmorris
    jeffmorris Journeyman
    I think that NEMA 23 stepper motors require external stepper drivers.
  4. DanW
    DanW New
    I've checked the wiring - all good. Well, Im going to swap the motors. Nema 23 doesnt require external drivers.
  5. DanW
    DanW New
    It was the driver. I'll replace it if I ever need 4th axis. Till then I will use 'A' axis, that is cloned 'Y'. I've ordered a new motor just in case. Thanx for your help!
  6. Alex Chambers
    Glad you got it sorted.
