Nema 23 HighTorque (Voltage and amperage recommendation)
Discussion in 'Motors' started by Cecil W Clontz, Mar 5, 2019.
  1. Cecil W Clontz
    I'm planning to purchase a C-Beam linear actuator bundle from the OpenBuilds store. I plan to use the DQ542MA stepper driver driven by an arduino Uno running Grbl. This is only going to be a single axle and not a 3-axis CNC. My load on the gantry will be maybe 3 lbs or less but I need it to run reliably and for a long time. Since these steppers are 24-48V and I believe 2.6A, my question is whether I should power these using 24V or 48V? And should I set the controllers for 2.6A or will I benefit from running these a little lower amperage?
    My apologies if this has been asked before.
  2. CNCMD
    CNCMD Journeyman
    High Torques are I believe 3A. You could run 24V and be fine with one axis.
  4. Cecil W Clontz
  5. Cecil W Clontz
    Thank you
