Nema 17 with aTB6600 driver
Discussion in 'General Talk' started by Johannes1969, Apr 16, 2018.
  1. Johannes1969
    Hi Gary
    Set $23=1 Top left home location.
  2. Gary Caruso
    I think you might have some things set up backwards, and it thinks it's homing to the -199 instead of +199?
    0,0,0 should be lower left corner from there positive jogs for X should move it left to right, and positive jogs in y should move lower to upper.. is this correct?
  3. Johannes1969
    If I change any setting then Homing and cutting direction is the same. after homing cutting also move towards the switch so it cuts of straight away.
    If I change it to $23=2 or $23=0 the same happens. I got $3=5 and $23=0 move to the correct directions but then it give me the -199 on the X Axis.
  4. Johannes1969
    Here is my current settings
  5. Gary Caruso
    you have to get the Jog going in the right direction before you worry about the homing, most people home to 0,0,0 which would be lower left corner
  6. Gary Caruso
    you can put the home in the upper left but make sure to change the origin on your drawings so the G-code start point turns out right
  7. Johannes1969
    My Jogging is going to the right direction. I am not sure how to get the G-Code to start point to right.
  8. Gary Caruso
    It would be in the drawing or cam software you are using, you need to set the zero work coords position, so it starts in the upper left of the work in your case.
    what are you using?
  9. Johannes1969
    Hi, i am using cambam
  10. Gary Caruso
    Ok, i've never used cambam so you will have to find out how to move the origin in that.
  11. Johannes1969
    Hi Gary
    I sorted out Cambam got the origin sorted everything working well. Thank you very much for your help it is great to speak to someone who know what they talking about.
    I there somewhere I can post an great review for you for excellent help and knowledge.
    GrayUK likes this.
  12. Gary Caruso
    No problem Johannes, could like my posts I guess?
    Make sure to post some pics of your build and some projects!
    Gary
    GrayUK likes this.
