Need to adjust Motor Current on CNC xPRO v4?
Discussion in 'Controller Boards' started by fabo1138, Oct 19, 2019.
  1. fabo1138
    fabo1138 New
    Completed building an Openbuilds LEAD 1010 with xPRO V4 controller and working fine with no issues.
    I've only run a few jobs of 10 minutes or so and noticed the motors were warm when just on and idling.
    I didn't see anything about setting motor current on the xPRO V4 but the V3 wiki has a procedure to set.
    Any need to check or set the motor current on the xPRO V4? I have equipment to check if there is a procedure.
    Stepper motors do, and should, get warm. Just not warm enough to cause damage (melting plastic insulation etc)
