I am New to this and am having difficulty connecting my OPT Laser PLH3D-XT-50 to my 1515 Open Build CMC. I have tried everything but does not won't to stay on or burn. My black box that it is connect too is X32. Seems to have very weak power. The light flashes on the Laser a bit then goes off. I would appreciate any suggestions on how to get this working. Thank you Andre
$0=10.0 ; Step pulse time, microseconds $1=255 ; Step idle delay, milliseconds $2=0 ; Step pulse invert, mask $3=0 ; Step direction invert, mask $4=0 ; Invert step enable pin, boolean $5=7 ; Invert limit pins, boolean/mask $6=1 ; Invert probe pin, boolean $8=0 ; Ganged axes direction invert as bitfield $9=1 ; PWM Spindle as bitfield where setting bit 0 enables the rest $10=511 ; Status report options, mask $11=0.010 ; Junction deviation, millimeters $12=0.002 ; Arc tolerance, millimeters $13=0 ; Report in inches, boolean $14=0 ; Limit pins invert, mask $15=0 ; Coolant pins invert, mask $16=0 ; Spindle pins invert, mask $17=0 ; Control pins pullup disable, mask $18=0 ; Limit pins pullup disable, mask $19=0 ; Probe pin pullup disable, boolean $20=0 ; Soft limits enable, boolean $21=0 ; Hard limits enable, boolean $22=0 ; Homing cycle enable, boolean (Grbl) / mask (GrblHAL) $23=3 ; Homing direction invert, mask $24=100.0 ; Homing locate feed rate, mm/min $25=2000.0 ; Homing search seek rate, mm/min $26=250 ; Homing switch debounce delay, milliseconds $27=5.000 ; Homing switch pull-off distance, millimeters $28=0.100 ; G73 retract distance, in mm $29=0.0 ; Step pulse delay (ms) $30=1000.000 ; Maximum spindle speed, RPM $31=0.000 ; Minimum spindle speed, RPM $32=1 ; Laser-mode enable, boolean $33=5000.0 ; Spindle PWM frequency $34=0.0 ; Spindle off Value $35=0.0 ; Spindle min value $36=100.0 ; Spindle max value $37=0 ; Stepper deenergize mask $39=1 ; Enable printable realtime command characters, boolean $40=0 ; Apply soft limits for jog commands, boolean $43=1 ; Homing passes $44=4 ; Homing cycle 1 $45=3 ; Homing cycle 2 $46=0 ; Homing cycle 3 $62=0 ; Sleep Enable $63=3 ; Feed Hold Actions $64=0 ; Force Init Alarm $65=0 ; Require homing sequence to be executed at startup $70=7 ; Network Services $73=1 ; Wifi Mode $74=NaN ; Wifi network SSID $75= ; Wifi network PSK $100=198.109 ; X-axis steps per millimeter $101=198.109 ; Y-axis steps per millimeter $102=199.100 ; Z-axis steps per millimeter $110=3500.000 ; X-axis maximum rate, mm/min $111=3500.000 ; Y-axis maximum rate, mm/min $112=1000.000 ; Z-axis maximum rate, mm/min $120=350.000 ; X-axis acceleration, mm/sec^2 $121=350.000 ; Y-axis acceleration, mm/sec^2 $122=350.000 ; Z-axis acceleration, mm/sec^2 $130=1180.000 ; X-axis maximum travel, millimeters $131=1270.000 ; Y-axis maximum travel, millimeters $132=90.000 ; Z-axis maximum travel, millimeters $320=NaN ; Hostname, max: 64 $322=192.168.5.1 ; IP Address $323=192.168.5.1 ; Gateway $324=255.255.255.0 ; Netmask $325=23 ; Telnet port $326=80 ; HTTP port $327=81 ; Websocket port $341=0 ; Tool Change Mode $342=30.0 ; Tool Change probing distance $343=25.0 ; Tool Change Locate Feed rate $344=200.0 ; Tool Change Search Seek rate $345=200.0 ; Tool Change Probe Pull Off rate $346=1 ; Restore position after M6 as boolean $370=0 ; Invert I/O Port Inputs (mask) $384=0 ; Disable G92 Persistence $396=30 ; WebUI timeout in minutes $397=0 ; WebUI auto report interval in milliseconds $398=35 ; Planner buffer blocks $481=0 ; Autoreport interval in ms $I=leadmachine1515
You can post multiple pics in one reply Some of your attachments didn't work, use the Upload a File button Regardless, not seeing anything obviously wrong. You aren't maybe running jobs with S0-255 instead of S0-1000
Your laser CAM workflow outputs S-commands that sets the power. S0 for 0% and should be S1000 for 100%. S0 as in "S"-Zero, not as in "oh"
