need help workbee ??
Discussion in 'General Talk' started by olivier gauthier, Apr 22, 2020.
  1. olivier gauthier
    hi ,i have a workbee it won't work (doesn't move ... no power) i have verified the wire ok , motor ok, arduino comunicate whit openbuild control , dr8825 power in and at the right volt. it'a 1 month that i try to make this work ... i don't know what else to try . can someone help me figure this out??
    - Set $4=0 (DRV8825s on a CNC Shield? They need $4=0, all our controllers use $4=1)
    - The tiny little breakout boards are a thermal nightmare, you're lucky to get 0.8-1A RMS out of a DRV8825 with those before they thermal shutdown (looks on, but isnt, or just skips a tonne of steps, or worse, dies) - and even if it works is sooo underpowered for a workbee!
    - Consider a real controller like OpenBuilds BlackBox 4X Documentation with 4A stepper drivers (3.2A RMS)
  3. Giarc
    I had those drv8825s with a cnc shield for starters. They were overheated way too easily. I upgraded to the DQ542MAs with my arduino before I had even completed the build and I am so glad I did. However, it is cheaper and way easier now to get the BlackBox.
