Need Help Interface g code issues
Discussion in 'Interfaces' started by ZZEUSCHEL, Nov 12, 2021.
  1. ZZEUSCHEL
    ZZEUSCHEL New
    Hi just got my interface a few days ago I've been trying to run my first job using the included USB flash drive. the job comes up as a green g code file on the interface, the job starts to run smooth but as soon as the router starts to go along my first circle the machine starts skipping as it cuts around the circle. Any help would be greatly appreciated!!
  3. ZZEUSCHEL
    ZZEUSCHEL New
    Thank you for the reply @Peter Van Der Walt, I feel as if its something to do with the way I'm exporting the g code from my computer. I don't think the machine or wiring have any issues just because for the last few weeks I've been running the machine smoothly with a wired setup. no interface just a laptop with the control software and a wire plugged into the backbox. its only when i try to use the interface that it does the skip like movements. its hard to explain but its like its intentionally skipping.
  4. ZZEUSCHEL
    ZZEUSCHEL New
    Should have clarified this in the first post its my first job using the interface my bad
    Interface just sends the gcode along, just like the computer would. Switch back to computer, run the same file, same settings, same zero point etc to confirm
  6. ZZEUSCHEL
    ZZEUSCHEL New
    I will switch back to computer and let you know. Open builds cam has a save g code button am I supposed to be using that to get my g code file? I'm very new to all this so I'm just trying to make sure I'm putting the right file onto the flash drive. I just feel like its something to do with the file but I could be wrong. I only use open Builds cam at the moment so that's where I'm doing everything tool path and g code related.
    Correct, save Gcode.
  8. ZZEUSCHEL
    ZZEUSCHEL New
    So I did switch back to computer and I had no issues running a job on my machine. I've tried a lot of different things to make the interface work but it does the skipping every time. At this point im most likely going to try and return the interface and ill have to go back to using a laptop.
  9. Peter Van Der Walt
    Is your Interface Firmware up to date? V1.47 is current
    docs:interface:firmware-update [OpenBuilds Documentation]
    Post some pics of the "skipping" as machine going off path is unlikely to be Interface. Or perhaps skipping is the incorrect word, thus putting us on the wrong Troubleshooting path. Please elaborate?
    #9 Peter Van Der Walt, Nov 21, 2021
