nch02 control board
Discussion in 'Controller Boards' started by matur61, Aug 1, 2019.
  1. matur61
    matur61 New
    Hello,
    I recently made a workbee 1000 x 1000 and I used as controller board a nch02 made by novusun.
    I connected the motors through TB6660 drivers and, at the beginning, everything seemed to work fine.
    I made quite complicated models using Fusion 360 and its cam software using mach3/milling as post processor.
    The problem I'm experiencing is that I continuously loose the zero workpiece.
    There are specific moments in which the Y axis "trembles" meaning that the two Y motors make a lot of short movements back and forward for 2 to 4 seconds. After that the tools goes on but the zero point changes along the Y directions.
    Obviously I checked mechanically and, in doubt, I changed the TB6660 drivers.
    I hope there is someone that can give me a hint.
    Thanks for any help
  2. KronBjorn
    KronBjorn New
    Hi,
    Did you solve your problem, and is it working OK for you ?
    I am looking in to using the NCH02 for my workbee.
