My second build, OX.
Discussion in 'CNC Mills/Routers' started by scottyd, Apr 15, 2016.
  1. scottyd
    scottyd New
  2. scottyd
    scottyd New
    I made a disappointing 45 dollar mistake last night.. I was working on getting my Z axis done. I decided to use one of my smaller motors for, its a 6 wire 287in oz, brand new motor, it was a spare from the old machine. I guess what little wiring info I could find on it on the net was wrong... I double checked it, hooked it up with the proper resistor and sure enough blew the z board out on my Gecko... Just my luck! I learned how to trouble shoot the Gecko a little bit. I have a replacement G250xr3 board coming. Just another set back.
  3. GrayUK
    Tough luck my friend. :banghead:
    It happens a lot. :rolleyes:
    scottyd likes this.
  4. scottyd
    scottyd New
    The Gecko has been great.. On my first project at first I was using those Chinese 6560 Drivers and it seemed like if you looked at them wrong something would blow. lol
    last night I worked on mounting home and limit switches...
  5. scottyd
    scottyd New
    I made the machines first cuts last night to build my router clamps. At first I zip tied the router the z axis and cut a couple out of plywood. I mounted the router with those and cut a new set out of delrin. Eventually when I get the machine fully tuned and as much flex eliminated as possible I'll cut a set from aluminum.
    Here's a video, I slowed the rates down while watching it like a hawk.
  6. scottyd
    scottyd New
    Clamps mounted
    Next is a dust shoe
    GrayUK likes this.
  7. GrayUK
    Excellent job. Well done. :thumbsup::thumbsup::thumbsup:
    The world is your oyster now! :)
    scottyd likes this.
  8. scottyd
    scottyd New
    Indeed!!
    Here's the start of the dust shoe. I'm trying to decide what material to use as brushes.
  9. GrayUK
    The only brush that comes to mind, is the type used on the bottom of doors as draught excluder. :rolleyes:
    Only snag is that it is rigid, so a squarish fitting is needed. I have seen round ones but I don't know where they get flexible brush from.
    You could buy a load of paint brushes and break the handles off, and use them. :D:D
    Although I must admit, I haven't shopped around for the product.
    I can't see the top of the vacuum pipe, but can I suggest some kind of frame built onto the X axis, to support the hose etc. As I see the pipe at the moment, it is liable to create a pulling action on the Z axis. Just a thought.
    scottyd likes this.
