Multi-z for LEAD CNC1010
Discussion in 'General Talk' started by Allegra, Apr 29, 2024.
  1. Allegra
    Allegra New
    Hello! I'm interested in buying a LEAD CNC 1010 AND I'm thinking about the potentiality of a Multi-z.
    For my necessity, a 1010 would be more than enough, but a multi-z would make my workflow much better. According to measurements, a 2-z should theoretically fit. But I don't see any info about this anywhere. What do you say? Should I go for a 1015 only for this?
    If so, is it possible to upgrage a 1010 to a 1015 later on?
    Best,
    Allegra
    I'd say get the LEAD1515. While a 1010 covers your current needs, you'll soon find work for the larger bed!
    Modifications are possible, but often a lot of effort and trial and error (the 1010 differs quite a bit from the 1515 - dual X rails, totally different Z axis - moving carriage vs moving beam etc)
  3. Allegra
    Allegra New
    Okay! Thank you (and for the fast answer)! I'm trying to navigate all the information as much as possible.
    I see the italian reseller Openbuildsitalia.com sells a 1510 version but here doesn't exist. Why is it the case?
    Check with the store via Support > New Ticket for a list of official resellers and more info on reseller's versions of core machine designs.
