Motors for mini mill conversion
Discussion in 'Motors' started by Pixel_Porpoise, Oct 9, 2023.
  1. Pixel_Porpoise
    Hi all,
    I'm shopping for suitable motors to go with my (leadscrew) Taig mill conversion, probably going to go with the blackbox x32 as i'm new to the whole cnc thing and it sounds relatively plug and play!
    Which of these would be best with the blackbox please?
    https://www.omc-stepperonline.com/e...-04oz-in-2-8a-57x57x56mm-4-wires-23he22-2804s
    The dual shaft one had particularly low resistance/inductance in bipolar parallel
    https://www.omc-stepperonline.com/d...nm-178-4oz-in-3a-57x56mm-8-wires-23hs22-3008d
    Stepper Motor 1.5Nm Nema23
    Ours would be first choice Electronics - Stepper Motors - OpenBuilds Part Store
    For 3rd party Motors:
    Basically you want to check that you have
    • Bipolar Motors
    • 3-6v Coil rating (higher will be slow on acceleration)
    • 1-2mH Inductance (higher will limit top speeds)
    • 1.7-4A Max Current
